Lenovo General Lenovo phones discussion, firmwares, solution, help |
01-20-2016, 06:50 | #1 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Lenovo Phones / Tablets Test Points (TP) Here TA should be sought only if the PC does not react to connect a standard USB cable, you turn off the phone! Type Of TP ---------------------------- All TP can be divided into types of following items:
TP combination of buttons ----------------------------- P700 hold "Volume + and -" to insert the battery, connect P770 Sandwiched "Volume +" P780 USB when connected to press Reset S850 Sandwiched "Volume +" T2-A7-10F Sandwiched "Volume +" Search TP ------------------------------ 1- The combination of buttons
This option is only used when it is not working or not B.1The principle is as follows. In the off tf through ballast resistor 800-1000 ohms closes a certain point on the ground (minus food) or less two points together. !!! Warning, you can not close the point without a resistor - TF will burn if the supply line loop ends with "weight". Thus Tp is translated into a special mode which does not require a loader apparatus. When you connect your phone to the PC with the TA will be found with the equipment PID_0003 see above var.1 if so then install the driver if nothing had happened and found a device with a different pid then try another point. For greater simplicity, it is recommended to open the "Device Manager" and turn the sound on your PC. So it is possible to use the program USBdeview that show was, whether the device is connected with the correct pid if you do not have time to notice. USB_dev.rar 198,11K186 times Downloaded An example of the found devices with pid = 0003 TP circuit CT ------------------------------ A850 A660 A789 P700 P780 A630 S60-A Source from Lenovo ...! Thank | You Last edited by aZimBahar; 02-16-2016 at 14:21. |
The Following 24 Users Say Thank You to aZimBahar For This Useful Post: |
01-20-2016, 07:37 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: "I work for Good weekend"
Member: 765990 Status: Offline Sonork: 100.1582347 Thanks Meter: 207 | Hi brother, That is good and nice help to all of us. the Most dead set in Market is Lenovo A319 if there is test point to alive this set. That will be a also good help. Thanks Br, Raja |
The Following 3 Users Say Thank You to raja16sep For This Useful Post: |
01-20-2016, 07:54 | #3 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | @...raja16sep This model should be detect in PC without test point Flash your phone with 'Lenovo_A319_S313_MOD2" file to recover Back |
The Following 3 Users Say Thank You to aZimBahar For This Useful Post: |
10-02-2016, 11:35 | #11 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2619613 Status: Offline Thanks Meter: 1 | thanks you sir thanks you sir for testpoint when i short it with 800 ohms resister it work thank you very much |
The Following User Says Thank You to fahadiqbal25 For This Useful Post: |
12-30-2016, 16:49 | #13 (permalink) |
Freak Poster Join Date: Sep 2016 Location: **S♦A♦R** Age: 29
Member: 2621055 Status: Offline Sonork: 100.1675233 Thanks Meter: 144 | Lenov s650 dead boot fix 100% FIRST IN THE WORLD LENOVO S650 DEAD BOOT REPAIR WITH TEST POINT JUST SHORT THIS RESISTOR IN THIS PICTURE AND FLASH WITH SP FLASHTOOL http://www.4shared.com/photo/1T_2N_Dbba/image_02.html DONT FORGET "THANX" |
The Following User Says Thank You to wafi95 For This Useful Post: |
12-30-2016, 21:33 | #14 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Quote:
The Following User Says Thank You to ribbentrop For This Useful Post: |
