Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 10-06-2016, 04:54   #1 (permalink)
Member: 1801908
Thanks Meter: 11
leanvo A7000a how to root plz help me
android v6.0 marshmallow
plz help me thanku
The Following 7 Users Say Thank You to arman1432 For This Useful Post:
Old 10-06-2016, 13:46   #2 (permalink)
Member: 1825227
Thanks Meter: 3
Exclamation Lenovo Phones ROOT
Dear sir,
Kindly update lenova vibe k5 plus rooting with solution
rgds....Madan
The Following 3 Users Say Thank You to madanchennai For This Useful Post:
Old 10-07-2016, 21:16   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,239
Originally Posted by madanchennai View Post
Dear sir,
rgds....Madan
- Download custom recovery for K5 Plus - HERE (twrp-k5-3.0.2-r3_scritch007.img)
- Download latest SuperSU - HERE
Instructions :
1. Activate the Developer options (Settings> About phone> Device Information> to tap 7 times in Build number)
2. Enable USB debugging (Settings> Developer> USB Debugging)
3. Enable OEM unlock (Settings> Developer> Unlock OEM)
4. Connect the phone with the USB cable to the computer
5. Install the drivers that come on the CD cell partition.
6. Install "Minimal adb and FlashBoot" (if not already installed).
7. Download the TWRP recovery created by @Shreps, and copy it to the folder where abd is installed.
8. Run the Minimal adb and FlashBoot program or open the command line in the folder where the abd installed.
9. Run the command "adb devices" to confirm the connection. If you have never done before in this cell, the cell must confirm the adb connection.
10. When the adb confirm the connection, run the "adb reboot bootloader" Fastboot command to enable the functionality.
11. If you want a temporary recovery run the "fastboot boot twrp-k5-3.0.2-r3_scritch007.img" command. If you want to permanently run the "fastboot flash recovery twrp-k5-3.0.2-r3_scritch007.img" command.
12. You can now use the TWRP recovery in the K5 / K5 plus!
Credits to 4pda forum for instructions / Scritch for TWRP recovery.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 14 Users Say Thank You to Brka For This Useful Post:
Old 10-07-2016, 21:30   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,239
plz help me thanku
- Download SPFlashTools - HERE
- Download attached scatter file
- Download TWRP recovery - HERE
- Download SuperSU - HERE or some latest from my previous post
Instructions :
1. Download TWRP recovery, download scatter, put both files in same folder
2. Open SPFlashTools, load scatter file, check if recovery is loaded and ticked, press download, connect powered off phone to cable
3. Download supersu and put on memory card, insert it in phone
4. Reboot to cwm/TWRP recovey (volume up + power on)
5. Select update from sdcard, select supersu zip file
b.r.
ALex
__________________
The Following 9 Users Say Thank You to Brka For This Useful Post:
Old 11-02-2016, 20:54   #5 (permalink)
..::SADHAN::..'s Avatar
Member: 1430165
Sonork: 100.1594449
Thanks Meter: 463
Thumbs up Lenovo TAB 2 A7-30HC,, How To Root?
Lenovo TAB 2 A7-30HC (Android 5.0.1)
Try, Kingo ROOT Not Done
How To Root?
The Following User Says Thank You to ..::SADHAN::.. For This Useful Post:
Old 11-23-2016, 01:56   #6 (permalink)
Member: 976188
Thanks Meter: 6
Root Lenovo A2016b30
Hi.
I need root for Lenovo A2016b30 with android 6.0 MT6735M
Any solution for root?
this is
Tanks advances
The Following User Says Thank You to alangersain For This Useful Post:
Old 11-26-2016, 06:31   #7 (permalink)
Member: 2496811
Thanks Meter: 6
lenovo a7020a48 root
lenovo a7020a48 how to root plz any body help
Old 11-30-2016, 08:02   #8 (permalink)
Member: 2496811
Thanks Meter: 6
Old 12-10-2016, 05:51   #9 (permalink)
Member: 2576510
Sonork: www.sonork.com
lenovo a7000-a how to root plz any body help
Old 12-29-2016, 19:14   #10 (permalink)
Crazy Poster
Member: 1589436
Thanks Meter: 7
lenovo k6 power need root sealution v6.0.1 plzz help
lenovo k6 power need root sealution v6.0.1 plzz help sir
The Following User Says Thank You to pintu gsm For This Useful Post:
Old 12-31-2016, 06:01   #11 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,239
It will not appear soon for general population, so better don't wait for it.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 01-03-2017, 13:08   #12 (permalink)
Member: 2241371
how to root lenova a7010a48 any body plss help
Old 01-03-2017, 20:27   #13 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,239
All needed tools (custom recovery, bootloader unlock, HOW-TO), download - HERE
b.r.
Alex
__________________
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 01-05-2017, 17:27   #14 (permalink)
Member: 2669033
Sonork: 100.1676548
Thanks Meter: 10
don,t try
don,t try to root lenovo becoz i have been tried in marshmallow version but alot of lenovo root failed many of root success
Old 01-05-2017, 19:59   #15 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,239
You probably dont know difference between "safe" and "unsafe" root.
Safe root is via custom recovery, injecting SuperSU Installer (binaries and startup script(s)).
Potentially unsafe root is via all those Rooting apps, pc softwares etc.,
where potential exploits, and unsafe SuperUser apps can screw/crash the system.
Try to distinguish those two scenarios.
b.r.
Alex
__________________
The Following 3 Users Say Thank You to Brka For This Useful Post:
Page generated in 0.27740 seconds with 8 queries
