Lenovo Phones / Tablets Test Points (TP) Here Test Point (Eng. Test points - the key point) - points on the board mobile phone, making it possible to record the phone's memory (usually in the boot area) information in the event of software or hardware errors. TA should be sought only if the PC does not react to connect a standard USB cable, you turn off the phone! Type Of TP ---------------------------- All TP can be divided into types of following items:
TP combination of buttons ----------------------------- P700 hold "Volume + and -" to insert the battery, connect P770 Sandwiched "Volume +" P780 USB when connected to press Reset S850 Sandwiched "Volume +" T2-A7-10F Sandwiched "Volume +" Search TP ------------------------------ 1- The combination of buttons
This option is only used when it is not working or not B.1The principle is as follows. In the off tf through ballast resistor 800-1000 ohms closes a certain point on the ground (minus food) or less two points together. !!! Warning, you can not close the point without a resistor - TF will burn if the supply line loop ends with "weight". Thus Tp is translated into a special mode which does not require a loader apparatus. When you connect your phone to the PC with the TA will be found with the equipment PID_0003 see above var.1 if so then install the driver if nothing had happened and found a device with a different pid then try another point. For greater simplicity, it is recommended to open the "Device Manager" and turn the sound on your PC. So it is possible to use the program USBdeview that show was, whether the device is connected with the correct pid if you do not have time to notice. USB_dev.rar 198,11K186 times Downloadedhttp://lenovo-forums.ru/public/style..._types/zip.gif http://lenovo-forums.ru/uploads/mont...8573_thumb.jpg An example of the found devices with pid = 0003 http://lenovo-forums.ru/uploads/mont...5117_thumb.jpg TP circuit CT ------------------------------ A850 A660 A789 P700 P780 A630 S60-A Source from Lenovo ...! Thank | You |
Hi brother, That is good and nice help to all of us. the Most dead set in Market is Lenovo A319 if there is test point to alive this set. That will be a also good help. Thanks Br, Raja |
@...raja16sep This model should be detect in PC without test point Flash your phone with 'Lenovo_A319_S313_MOD2" file to recover Back :) |
lenevo a6000 tp available ? |
hello,any one got tp for lenovo a616?want to force preloader mode |
test point на Lenovo s860s China? please |
TP for Lenovo A516 please?Tthaks. |
Is there Lenovo A889 Testpoint available ? |
do you have TP for A706? |
Hello, the test point for Lenovo K920 (Z2 Pro)? Thank you |
thanks you sir thanks you sir for testpoint when i short it with 800 ohms resister it work thank you very much |
lanovo s898t testpoint need |
Lenov s650 dead boot fix 100% FIRST IN THE WORLD LENOVO S650 DEAD BOOT REPAIR WITH TEST POINT JUST SHORT THIS RESISTOR IN THIS PICTURE;);););) AND FLASH WITH SP FLASHTOOL http://www.4shared.com/photo/1T_2N_Dbba/image_02.html DONT FORGET "THANX":D:D |
need test point lenovo A2010a |
