Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 09-06-2017, 07:52   #31 (permalink)
Member: 1360016
Sonork: 100.1637900
Thanks Meter: 14
Lenovo X3a40 test point
Old 09-14-2017, 06:50   #32 (permalink)
antoniogonzalez's Avatar
Member: 174173
Thanks Meter: 115
Lenovo K6 K33A42/48/36
I have cable EDL not change 9008
Qualcomm HS-USB Diagnostics 900E
TP requiered
Old 09-14-2017, 20:30   #33 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
TP requiered
Check if under device manager / disk drives, you have some new disk drive,
And, if so - just use some partitioning software (ie: minitool partition wizard),
delete first (or 1st + 2nd + 3rd ) partition.
Disconnect from cable, reboot phone - it will go into port9008
Then - simply re-flash it.
Don't fully format device - you will end with no imei / baseband etc.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 09-15-2017, 05:25   #34 (permalink)
Member: 174173
Thanks Meter: 115
b.r.
Alex
not generate disk drives
other solution ?
Old 09-15-2017, 10:37   #35 (permalink)
Member: 1970263
testpoin zuk z2 plus
my device not 9008 qd loader mode only qualcomm hs usb diagnostick 9006 this/qualcomm emmc storage usb mode not flashing qfil and other tools not fastboot volume down and up my device totally dead conditions.
Please help me testpoint lenovo z2 plus thank
Old 09-15-2017, 20:36   #36 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
other solution ?
Testpoint.
b.r.
Alex
__________________
Old 09-15-2017, 20:45   #37 (permalink)
Member: 174173
Thanks Meter: 115
Testpoint.
b.r.
Alex
Yes Sr I need,
search and search nothing
Old 09-23-2017, 00:00   #38 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Check Board
Disconnect battery, short two-by-two, marked in red, insert cable,
if nothing, disconnect, repeat other two, try both directions.
b.r.
Alex
__________________
Old 09-23-2017, 17:07   #39 (permalink)
Member: 2216669
Sonork: shokryjoks
I need test point lenovo A560
please help me
Old 09-25-2017, 22:08   #40 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
please help me
Try with area marked in red, short first two from down to up, insert usb cable,
if nothing try other combinations (lower one + gnd, next two, etc.).
Or ... have you tried with EDL cable ?
(normal usb cable, with shorted green + black wire - then inserted into phone)
b.r.
Alex
__________________
Old 10-11-2017, 13:17   #41 (permalink)
Member: 186857
Thanks Meter: 13
For semi-bricked phones, ie - phones that doesnt go into "special" menu (volume up + power on),
with download option, usually after bad flash, (and since A6000 doesnt accept EDL cable),
phone must be disassembled and TP7 + TP9 must be connected, then usb cable inserted.
After that "Qualcomm HS-USB QDloader 9008" port appear, and you can flash it qith QFIL.
(Or other QCom flashing tool of your choice)
So, disassemble phone, take off back cover, and looking from back,
from right to left, there is SIM2 slot, left to it SDCard slot, and left from it
there is small IC, and a bit upper from it is TP7 and TP9.
Check attached picture.
b.r.
Alex
Good work!I tested,succesfull repair Lenovo A 6000 totally dead boot!Thanks
Old 11-06-2017, 13:28   #42 (permalink)
cbcelular's Avatar
Member: 217679
Thanks Meter: 95
Check Board
Solved your Lenovo K6 phone? Do you have his TP?
Old 11-06-2017, 22:40   #43 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Don't be lazy, and try that red-marked area test-points.
b.r.
Alex
__________________
Old 11-06-2017, 23:34   #44 (permalink)
cbcelular's Avatar
Member: 217679
Thanks Meter: 95
b.r.
Alex
I have already done the tests marking the two points at a time as it shows photo circled in red, did not go into cualcomm mode 9008 I need the correct pinout to make the TP urgent
Old 11-07-2017, 00:58   #45 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Try some of these ...
second picture is other side of the board.
market TP's need to be shorted to GND.
first connect cable, and measure if some point
does have voltage 3.3v or more, if yes, don't short it to GND, it's 100% not TP.
test and post results.
b.r.
Alex
__________________
Page generated in 0.23729 seconds with 9 queries
