Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 05-17-2017, 08:23   #1 (permalink)
Member: 2395079
Thanks Meter: 9
Lenovo S60a Dead after flash
Hello,
Lenovo S60a dead after flash s232 rom from s227
after flash vibrate only and when connect to pc too much drives open and ask for format disk
showing h9006 port on device manager but not flashing from any tool or device
please expert help me..
The Following User Says Thank You to alnajafmobiles For This Useful Post:
Old 05-17-2017, 10:06   #2 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 9,862
Before flash which Android version was inside ?
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Old 05-17-2017, 10:32   #3 (permalink)
Member: 2395079
Thanks Meter: 9
before flash S60-a_USR_S227_1508062043_Q2040.1_ROW
and flash with S60-a_S232_151021_ROW-QPST-QFIL
Old 05-17-2017, 11:02   #4 (permalink)
boganice's Avatar
Member: 5184
Thanks Meter: 150
Try to find firmware S60-a_USR_S227_1508062043_Q2040.1_ROW backed up from working device and reflash it again, you will find firmware uder unbrick firmware threads.
Best Regards,
The Following User Says Thank You to boganice For This Useful Post:
Old 05-17-2017, 11:22   #5 (permalink)
Member: 492386
Sonork: 100.1601487
Thanks Meter: 63
Download firmware,flashtool,driver from this site,then install the flashtool,now extract the firmware and correctly select then connect this phone with pc pressing volume up,when the phone show on the port select area then click on download button,the firmware version is 5.0.1.its atested solution.
How to Flash Lenovo S60-a Firmware!
Download and install Lenovo S60-a USB Drivers.
Then Download and install QFil Flasher.
Download Rom of Lenovo S60-a firmware Password is lenovo4
Extract the rom.
Open Qfil flasher.
Specify the file in Programmer Path the file will be prog_emmc_firehose_8916.mbn
Now in Load XML specify raw_program_unparse and patch file.
Now click select port and power off your mobile. Volume + and Volume – and then connect usb cable.
Selected port will show like relink HS-USB QD Loader 9008.
Now Press Download Button. After Flash Mobile Phone will be restart.
The Following 9 Users Say Thank You to sony kabir For This Useful Post:
Old 05-17-2017, 14:29   #6 (permalink)
Member: 2395079
Thanks Meter: 9
Start Download
COM Port number:7
Switch To EDL
Download Fail:System.Exception: Failed to Switch to Emergency Download mode
at QC.QMSLPhone.Phone.QPHONEMS_SwitchToEDL()
at QC.SwDownloadDLL.SwDownload.SwitchToEDL()
Download Fail:Switch To EDL FailSystem.Exception: FireHose Fail
at QFIL.Tech.DownloadTech.SwitchToEDL()
Finish Download
The Following 2 Users Say Thank You to alnajafmobiles For This Useful Post:
Old 05-17-2017, 14:52   #7 (permalink)
Member: 492386
Sonork: 100.1601487
Thanks Meter: 63
Use edl cable,and post result.
Old 05-23-2017, 15:23   #8 (permalink)
Member: 2395079
Thanks Meter: 9
Same ERROR on EDL Cable
Old 05-23-2017, 17:33   #9 (permalink)
Member: 2395079
Thanks Meter: 9
phone is alive now after used this method on this Link
but IMEI is invalid now
someone know how to fix unknown baseband on this phone ?
Old 05-23-2017, 18:04   #10 (permalink)
Member: 1725884
Thanks Meter: 268
to fix unknown baseband you need efs file try to find on firmware folder...
Backup and restore EFS for Lenovo devices based on Qualcomm .
The Following 2 Users Say Thank You to abo anas zayan For This Useful Post:
Old 10-12-2017, 19:30   #11 (permalink)
Member: 2765174
Hello Guys,
I also undergo this case, so if anyone knows how to solve this, please share the method. Thank you all.
The Following User Says Thank You to Mg Mg dload For This Useful Post:
Old 09-08-2018, 13:32   #12 (permalink)
Member: 1812419
Thanks Meter: 106
flashing this file error bro
Old 10-19-2019, 18:16   #13 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,220
Extract the rom.
Open Qfil flasher.
For EDL Mode use Power off phone Vol up and Connect usb.
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
Page generated in 0.33868 seconds with 7 queries
