Lenovo General Lenovo phones discussion, firmwares, solution, help |
05-03-2017, 14:45 | #3 (permalink) |
Junior Member Join Date: Mar 2017 Location: banani dhaka bangladesh
Member: 2692026 Status: Offline Sonork: 100.1677152 Thanks Meter: 5 | lenovo s820 flash tool or i alredy try to sd card but no answer flash feild, instraction need bro ihave this file link but this file not woarking for me tell another solution how i flash this model Last edited by Brka; 05-03-2017 at 21:06. Reason: merged postsa |
05-03-2017, 14:50 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: UAE
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | TRY THIS WAY...... Install ROM: Need a memory card, create folder sdfuse and copy to install on this ROM (QSB tailed). A) Normal phone boot into Android OS, use a USB cable to connect PC, the pop-up screen, select USB mass storage devices, and turn on USB storage device; B) New sdfuse folder, unzip the downloaded firmware, and copied file QSB to the phone sdfuse directory; Note : Make sure before upgrading phone there is a certain amount of power T card upgrade process Long press VOLUP + POWER_KEY enter droidboot, a menu appears and select the fourth SDUPDATE, the bottom of the screen you can see the progress and status upgrade See "SDCARD UPDATE SUCCESS!!!" Indicates a successful upgrade Root: Lenovo S820E USB Mode debug, and then connected to the Lenovo , Run Root.exe tap any key.And your mobile reboot root ok |
The Following 2 Users Say Thank You to swapan For This Useful Post: |
