Lenovo General Lenovo phones discussion, firmwares, solution, help |
01-29-2018, 20:04 | #1 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2805362 Status: Offline Thanks Meter: 3 | Lenovo Tab4 10" / Lenovo TB-X304F - FRP Remove ? i have lenovo TB-X304F with frp lock can you help me to solve this problem? TNX Last edited by Brka; 01-30-2018 at 01:25. Reason: removed calling |
01-30-2018, 01:23 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,783 | Quote:
- boot into fastboot (volume down + power on) - select fastboot from on-screen menu, if not already there - unlock bootloader: fastboot oem unlock-go - after reboot, enter again fastboot - enter command: fastboot erase config - fastboot reboot frp should be gone. post results .... if not working, there is more dangerous method, by flashing FRP reset package. Download FRP Reset package : TB-X304F_S000038_170703_FRP_Remove_by_bRkA Archive pass: forum.gsmhosting.com All tools and files in archive. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 08-03-2018 at 22:25. Reason: fixed link | |
The Following 8 Users Say Thank You to Brka For This Useful Post: |
02-05-2018, 13:18 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | i won't be able to unlock bootloader FAILED (remote: oem unlock is not allowed) but FRP removed by flashing using QFIL thx bro ! Last edited by Brka; 02-05-2018 at 22:08. Reason: removed quoting |
02-08-2018, 18:37 | #4 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2809129 Status: Offline Thanks Meter: 4 | First off, super helpful post Brka. This is the furthest I've gotten since I accidentally bricked my new Lenovo Tab 4 10 behind FRP. I was able to flash the FRP reset package to my Tab using the files you provided, but I'm still getting the message that the Tablet has been reset and I can't get past it. I did receive a "Download Fail:FireHose Fail:FHLoader Fail: The system cannot find the file specified" error at the very end of the Flashing process with QFIL. There were no other errors in the flashing process though (e.g. Sahara). I did notice something odd after flashing the package and then starting up the tablet. If I just click through "Next" through the choose Language and Network (it still remembers my WiFi after flashing) pages, then I get a black screen where I can't do anything except reboot it. But if I just tap the WiFi then tap cancel, it goes through the normal Checking process and tells me to sign into my Google account. Is there something I'm doing wrong? Any help would be greatly appreciated. |
The Following User Says Thank You to Legile For This Useful Post: |
02-08-2018, 21:26 | #5 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,783 | Either you have windows/drivers issues or eMMC damaged. Try on other PC, with Win7, for beginning. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
02-13-2018, 03:55 | #6 (permalink) |
Member: 2809129 Status: Offline Thanks Meter: 4 | So I have tried with another PC, but I'm still getting the same issue as before. Is there a specific driver I should be using? And are there specific settings in QFIL Configuration that I should have applied? Sorry, I'm very new to QFIL and flashing in general. Thanks for the help. |
The Following 2 Users Say Thank You to Legile For This Useful Post: |
02-13-2018, 23:13 | #7 (permalink) | |
Try to make it work first, then flash FRP reset package. Download: TB-X304F_S000038_170703_ROW_QFIL archive pass: lenovo-forums.ru b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
02-14-2018, 07:03 | #8 (permalink) |
Member: 2809129 Status: Offline Thanks Meter: 4 | I got it to work! I had to download and install QPST 2.7 and flash using QFIL 2.7. The QFIL tool you provided wouldn't work on any of the PCs I used for some reason. In any case, thanks! I no longer have a paperweight! |
02-19-2018, 23:22 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,783 | Yes, solution is to read my posts in this thread - if needed, several times. Posted solution works 100%, as tested and reported by members. (If you have TB-X304F model.) b.r. Alex
07-26-2018, 14:57 | #11 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Everywhere
Member: 701592 Status: Offline Thanks Meter: 103 | Tried the first mode, but to no avail. And with Qfil I am unable to flash, I get this error (see pic). https://imgur.com/a/g8n59bZ |
The Following User Says Thank You to HeatGSM For This Useful Post: |
07-26-2018, 18:02 | #12 (permalink) | |
- Read how others solved problems - Put files in root of some folder on c:\ drive - ie : c:\x304frp - Use win7/32bit for succesfull flashing or compatibility mode - all problems arise of using Win7/64 or Win10. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
08-03-2018, 22:28 | #14 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,783 | Now download files from post #2. - Flash it as regular firmware, via QPST (QFIL). - After done, enter phone recovery, do "Wipe Data/Factory reset" - Reboot device - VOILA ! FRP should be gone. post results ... b.r. Alex
10-05-2018, 15:36 | #15 (permalink) | |
Freak Poster Join Date: Sep 2005 Location: lublin Age: 46
Member: 181258 Status: Offline Thanks Meter: 27 | Quote:
pass not work | |
The Following User Says Thank You to jacekchec For This Useful Post: |
