-   Lenovo (http://forum.gsmhosting.com/vbb/f958/)
-   -   Lenovo Tab4 10" / Lenovo TB-X304F - FRP Remove ? (http://forum.gsmhosting.com/vbb/f958/lenovo-tab4-10-lenovo-tb-x304f-frp-remove-2335520/)
smartpclab 01-29-2018 19:04
hello
i have lenovo TB-X304F with frp lock
can you help me to solve this problem?
TNX
Brka 01-30-2018 00:23
Originally Posted by smartpclab (Post 12934612)
hello Brka
TNX
- power off device
- boot into fastboot (volume down + power on)
- select fastboot from on-screen menu, if not already there
- unlock bootloader: fastboot oem unlock-go
- after reboot, enter again fastboot
- enter command: fastboot erase config
- fastboot reboot
frp should be gone.
post results .... if not working, there is more dangerous method, by flashing FRP reset package.
Download FRP Reset package : TB-X304F_S000038_170703_FRP_Remove_by_bRkA
Archive pass: forum.gsmhosting.com
All tools and files in archive.
b.r.
Alex
equinoks 02-05-2018 12:18
i won't be able to unlock bootloader
FAILED (remote: oem unlock is not allowed)
but FRP removed by flashing using QFIL
thx bro !
Legile 02-08-2018 17:37
First off, super helpful post Brka. This is the furthest I've gotten since I accidentally bricked my new Lenovo Tab 4 10 behind FRP. I was able to flash the FRP reset package to my Tab using the files you provided, but I'm still getting the message that the Tablet has been reset and I can't get past it.
I did receive a "Download Fail:FireHose Fail:FHLoader Fail: The system cannot find the file specified" error at the very end of the Flashing process with QFIL. There were no other errors in the flashing process though (e.g. Sahara).
I did notice something odd after flashing the package and then starting up the tablet. If I just click through "Next" through the choose Language and Network (it still remembers my WiFi after flashing) pages, then I get a black screen where I can't do anything except reboot it. But if I just tap the WiFi then tap cancel, it goes through the normal Checking process and tells me to sign into my Google account.
Is there something I'm doing wrong? Any help would be greatly appreciated.
Brka 02-08-2018 20:26
Either you have windows/drivers issues or eMMC damaged.
Try on other PC, with Win7, for beginning.
b.r.
Alex
Legile 02-13-2018 02:55
So I have tried with another PC, but I'm still getting the same issue as before. Is there a specific driver I should be using? And are there specific settings in QFIL Configuration that I should have applied? Sorry, I'm very new to QFIL and flashing in general. Thanks for the help.
Brka 02-13-2018 22:13
All needed (Drivers, flasher, etc.),can be found in stock rom archive.
Try to make it work first, then flash FRP reset package.
Download: TB-X304F_S000038_170703_ROW_QFIL
archive pass: lenovo-forums.ru
b.r.
Alex
Legile 02-14-2018 06:03
I got it to work! I had to download and install QPST 2.7 and flash using QFIL 2.7. The QFIL tool you provided wouldn't work on any of the PCs I used for some reason. In any case, thanks! I no longer have a paperweight!
smartpclab 02-19-2018 08:10
Frp
Hello,
Dosen't worked for me:confused:
Any other solution??
tnx
Brka 02-19-2018 22:22
Originally Posted by smartpclab (Post 12974831)
Hello,
tnx
Yes, solution is to read my posts in this thread - if needed, several times.
Posted solution works 100%, as tested and reported by members.
(If you have TB-X304F model.)
b.r.
Alex
HeatGSM 07-26-2018 14:57
Tried the first mode, but to no avail. And with Qfil I am unable to flash, I get this error (see pic). https://imgur.com/a/g8n59bZ
Brka 07-26-2018 18:02
- Read whole thread from beginning
- Read how others solved problems
- Put files in root of some folder on c:\ drive - ie : c:\x304frp
- Use win7/32bit for succesfull flashing or compatibility mode
- all problems arise of using Win7/64 or Win10.
b.r.
Alex
HeatGSM 08-03-2018 09:32
I have managed to write the firmware still the account is ON.
Brka 08-03-2018 22:28
Now download files from post #2.
- Flash it as regular firmware, via QPST (QFIL).
- After done, enter phone recovery, do "Wipe Data/Factory reset"
- Reboot device
- VOILA ! FRP should be gone.
post results ...
b.r.
Alex
jacekchec 10-05-2018 15:36
Originally Posted by Brka (Post 12934833)
- power off device
- fastboot reboot
frp should be gone.
b.r.
Alex
hi
pass not work :(
Page generated in 0.29369 seconds with 5 queries
