Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 01-29-2018, 19:04   #1 (permalink)
Member: 2805362
Thumbs up Lenovo Tab4 10" / Lenovo TB-X304F - FRP Remove ?
hello
i have lenovo TB-X304F with frp lock
can you help me to solve this problem?
TNX
The Following User Says Thank You to smartpclab For This Useful Post:
Old 01-30-2018, 00:23   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,250
Originally Posted by smartpclab View Post
hello Brka
TNX
- power off device
- boot into fastboot (volume down + power on)
- select fastboot from on-screen menu, if not already there
- unlock bootloader: fastboot oem unlock-go
- after reboot, enter again fastboot
- enter command: fastboot erase config
- fastboot reboot
frp should be gone.
post results .... if not working, there is more dangerous method, by flashing FRP reset package.
Download FRP Reset package : TB-X304F_S000038_170703_FRP_Remove_by_bRkA
Archive pass: forum.gsmhosting.com
All tools and files in archive.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 6 Users Say Thank You to Brka For This Useful Post:
Old 02-05-2018, 12:18   #3 (permalink)
equinoks's Avatar
Member: 21508
Thanks Meter: 108
i won't be able to unlock bootloader
FAILED (remote: oem unlock is not allowed)
but FRP removed by flashing using QFIL
thx bro !
The Following User Says Thank You to equinoks For This Useful Post:
Old 02-08-2018, 17:37   #4 (permalink)
Member: 2809129
First off, super helpful post Brka. This is the furthest I've gotten since I accidentally bricked my new Lenovo Tab 4 10 behind FRP. I was able to flash the FRP reset package to my Tab using the files you provided, but I'm still getting the message that the Tablet has been reset and I can't get past it.
I did receive a "Download Fail:FireHose Fail:FHLoader Fail: The system cannot find the file specified" error at the very end of the Flashing process with QFIL. There were no other errors in the flashing process though (e.g. Sahara).
I did notice something odd after flashing the package and then starting up the tablet. If I just click through "Next" through the choose Language and Network (it still remembers my WiFi after flashing) pages, then I get a black screen where I can't do anything except reboot it. But if I just tap the WiFi then tap cancel, it goes through the normal Checking process and tells me to sign into my Google account.
Is there something I'm doing wrong? Any help would be greatly appreciated.
Old 02-08-2018, 20:26   #5 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,250
Either you have windows/drivers issues or eMMC damaged.
Try on other PC, with Win7, for beginning.
b.r.
Alex
__________________
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 02-13-2018, 02:55   #6 (permalink)
Member: 2809129
So I have tried with another PC, but I'm still getting the same issue as before. Is there a specific driver I should be using? And are there specific settings in QFIL Configuration that I should have applied? Sorry, I'm very new to QFIL and flashing in general. Thanks for the help.
The Following User Says Thank You to Legile For This Useful Post:
Old 02-13-2018, 22:13   #7 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,250
All needed (Drivers, flasher, etc.),can be found in stock rom archive.
Try to make it work first, then flash FRP reset package.
Download: TB-X304F_S000038_170703_ROW_QFIL
archive pass: lenovo-forums.ru
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 02-14-2018, 06:03   #8 (permalink)
Member: 2809129
I got it to work! I had to download and install QPST 2.7 and flash using QFIL 2.7. The QFIL tool you provided wouldn't work on any of the PCs I used for some reason. In any case, thanks! I no longer have a paperweight!
Old 02-19-2018, 08:10   #9 (permalink)
Member: 2805362
Frp
Hello,
Dosen't worked for me
Any other solution??
tnx
Old 02-19-2018, 22:22   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,250
Hello,
tnx
Yes, solution is to read my posts in this thread - if needed, several times.
Posted solution works 100%, as tested and reported by members.
(If you have TB-X304F model.)
b.r.
Alex
__________________
Old 07-26-2018, 14:57   #11 (permalink)
HeatGSM's Avatar
Member: 701592
Thanks Meter: 98
Tried the first mode, but to no avail. And with Qfil I am unable to flash, I get this error (see pic). https://imgur.com/a/g8n59bZ
Old 07-26-2018, 18:02   #12 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,250
- Read whole thread from beginning
- Read how others solved problems
- Put files in root of some folder on c:\ drive - ie : c:\x304frp
- Use win7/32bit for succesfull flashing or compatibility mode
- all problems arise of using Win7/64 or Win10.
b.r.
Alex
__________________
Old 08-03-2018, 09:32   #13 (permalink)
HeatGSM's Avatar
Member: 701592
Thanks Meter: 98
I have managed to write the firmware still the account is ON.
Old 08-03-2018, 22:28   #14 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,250
Now download files from post #2.
- Flash it as regular firmware, via QPST (QFIL).
- After done, enter phone recovery, do "Wipe Data/Factory reset"
- Reboot device
- VOILA ! FRP should be gone.
post results ...
b.r.
Alex
__________________
Old 10-05-2018, 15:36   #15 (permalink)
Member: 181258
Thanks Meter: 26
Originally Posted by Brka View Post
- power off device
- fastboot reboot
frp should be gone.
b.r.
Alex
hi
pass not work
Page generated in 0.45213 seconds with 8 queries
