Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 10-05-2018, 20:32   #16 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,186
Originally Posted by jacekchec View Post
hi
pass not work
really ?
check attached pictures ...
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 11-30-2018, 21:26   #17 (permalink)
Member: 2879380
Can anyone help me understand this log?
22:08:59: ERROR: function: sahara_rx_data:237 Unable to read packet header. Only read 0 bytes.
22:08:59: ERROR: function: sahara_main:924 Sahara protocol error
22:08:59: ERROR: function: main:303 Uploading Image using Sahara protocol failed
Download Fail:Sahara Fail:QSaharaServer Fail:Process fail
Finish Download
Old 11-30-2018, 22:48   #18 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,186
In short: Usually means wrong drivers.
b.r.
Alex
__________________
Old 11-30-2018, 23:31   #19 (permalink)
Member: 2879380
But i have TB-X304F ?
b.r.
Alex
Old 12-04-2018, 11:04   #20 (permalink)
Member: 2879380
I finally got it to work.
But after that, I can not activate wifi?
Old 12-04-2018, 20:51   #21 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,186
hi
pass not work
Reflash device with ROM from post #7.
Check after flashing, does wifi turns on ?
Check settings / about device, does WiFi mac address exists ?
if it looks irregular - ie: 02:00:00:00:00:00 , then wifi ic has malfunctioned.
b.r.
Alex
__________________
Old 12-05-2018, 15:07   #22 (permalink)
Member: 2879380
Reflash device with ROM from ["]post #7[/URL].
b.r.
Alex
The WiFi mac address do not exist.
I haven't done Reflash because my qfile dont want to...
Old 12-06-2018, 21:44   #23 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,186
As already written, it will work only with correct drivers.
Clean/remove existing Qualcomm drivers, and install
Correct drivers in ROM archive from post #7.
ROM must be placed under root of c:\ drive (ie: c:\tab410 )
Preferrably win7/32bit, should work on Win7/64bit,
may also work on clean Win10.
p.s. WiFi / no mac address may be sign that somebody played before you with that device.
It may or may NOT be easy repairable, IF software problem at all.
b.r.
Alex
__________________
Old 03-14-2019, 10:19   #24 (permalink)
Member: 2631658
Successful flashing
Hello,
I just got everything worked with the fellow steps:
1. I had a pc with windows 7 32bit. If you can,please make a clean install of windows 7 and full updates.
2. I downloaded the file from Brka at post #7. At the beginning it was not flashing but I used the first version of QFIL v1-0-0-2 and it flashed without any problem e.g Sahara or any other.
3. After finishing and rebooting, the device is still locked with FRP. Then you will have to do the same procedure but this time using the file again from Brka at post #2.
4. After flashing and rebooting, everything is perfect.
Thanks a lot to Brka
The Following User Says Thank You to voltronsif For This Useful Post:
Page generated in 0.36988 seconds with 8 queries
