Lenovo General Lenovo phones discussion, firmwares, solution, help |
07-18-2016, 08:16 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: SURESH ELECTRONICS, INDIA Age: 49
Member: 216081 Status: Offline Sonork: 100.1614205 Thanks Meter: 55 | lenovo vibe shot z90a40 stuck in qualcomm 9006 |
07-21-2016, 23:30 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
or volume up + insert cable or volume down + insert cable. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
09-17-2016, 22:46 | #5 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Last two versions I have found... No S327 though... may be some OTA update... Z90a40_S363_160625_ROW Z90a40_S240_160119_ROW b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
07-07-2017, 22:12 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Check if, when phone is connected via cable, you can see some new hard disk drive under device manager. If yes, use some disk partitioning software, and erase first couple of partitions, then remove cable, it should appear as port 9008. If not visible as HDD drive, then only via testpoint. b.r. Alex
07-13-2017, 03:43 | #8 (permalink) |
Junior Member Join Date: Nov 2016 Location: Philippines
Member: 2645024 Status: Offline Thanks Meter: 0 | Phone is detected but so many partitions. How to delete read only partitions? I used minitool wizard but cannot delete read only disk I used diskpart but not solved Please help how to delete multiple partitions Thanks |
07-13-2017, 21:36 | #9 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | You just answered to an own problem ... Flash memory went read-only state. No software rerpairs / flashing possible. b.r. Alex
