Lenovo General Lenovo phones discussion, firmwares, solution, help |
02-27-2018, 16:34 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Lenovo ZUK Z2 Plus (Z2132)NEED TEST POINTS hi friends, mobile not show any com port, only light blink when i connect with pc. Need test point. Please help. Thanks, B.Uttam |
The Following User Says Thank You to uttam4u2002 For This Useful Post: |
02-28-2018, 01:19 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Prepare ROM and QFIL, install drivers, make a tea or coffe, and : - Unpack rom, load in QFIL, be ready to flash - Open device manager - Hold volume UP key + Insert usb cable - Still Hold volume UP, and now also press power on key, don't let go - watch in device manager, in one moment, it will appear Port 9008 - Immediately start flash process or - hold BOTH volume keys, insert cable, - still hold both volume keys, now press and hold power on, hold - wait until ADB device appears, - from fastboot, issue command: fastboot -i 0x2b4c oem reboot-edl - port 9008 should appear - flash device with qfil Hopefully will be done without issues. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
02-28-2018, 04:24 | #3 (permalink) |
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Well I try and post result.. Main problem is button strip damage. Thanks for reply.. i trying to connect strip connection. Last edited by Brka; 02-28-2018 at 17:05. Reason: removed quote |
03-22-2019, 13:51 | #4 (permalink) |
Junior Member Join Date: Dec 2013 Location: mangalore
Member: 2080027 Status: Offline Sonork: [email protected] Thanks Meter: 2 | lenovo z2132 edl pinout test pont |
