Lenovo General Lenovo phones discussion, firmwares, solution, help |
12-10-2017, 03:27 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: morocco
Member: 2149341 Status: Offline Thanks Meter: 31 | Lenovo Zuk Z2 Pro cant hard reset |
12-10-2017, 10:57 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: UAE
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | Quote:
Description Flash Your Own Risk Firmware Credit : mikeS | |
01-04-2018, 00:01 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | There's a way to reset device without unlocking bootloader or flashing, it's tricky though, but interesting. First of all, you'll need to download the loader for your device prog_ufs_firehose_8996_ddr_zuk.elf. Now download this program emmcdl and extract it into the same folder where the loader file is. You need to boot your device into edl mode, to do so, follow this.
Hold Shift + Right click inside the folder, then choose open command prompt window here. Now type and run these commands one by one and before you do, replace "X" with your port number: Code: emmcdl.exe -p COMX -f prog_ufs_firehose_8996_ddr_zuk.elf -e userdata Code: emmcdl.exe -p COMX -f prog_ufs_firehose_8996_ddr_zuk.elf -e cache Code: -e argument indicates to "erase" and after it comes the name of the partition or even the addresses you want to erase. I'm sorry my guide is a mess but I hope someone can find it useful anyway. Best regards |
The Following User Says Thank You to MiRoOo For This Useful Post: |
01-04-2018, 14:08 | #5 (permalink) | |
Freak Poster Join Date: May 2011
Member: 1580193 Status: Offline Thanks Meter: 22 | Quote:
01-04-2018, 22:09 | #7 (permalink) |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Lenovo Zuk Z2 Pro cant hard reset You may want to try again using this modified commands: Code: emmcdl.exe -p comx -f prog_ufs_firehose_8996_ddr_zuk.elf -MemoryName ufs -e userdata Code: emmcdl.exe -p comx -f prog_ufs_firehose_8996_ddr_zuk.elf -MemoryName ufs -e cache We've just specified the memory type the device uses by the argument -MemoryName, which is ufs for ZUK Z2 Pro. Last edited by MiRoOo; 01-05-2018 at 06:11. |
01-25-2018, 15:39 | #8 (permalink) | |
Version 2.15 Downloading flash programmer: prog_ufs_firehose_8996_ddr_zuk.elf Successfully open flash programmer to write: prog_ufs_firehose_8996_ddr_zuk.elf Waiting for flash programmer to boot Erasing Disk <?xml version="1.0" encoding="UTF-8" ?> <data> <log value="Binary build date: Jun 17 2016 @ 20:09:43"/> </data><?xml version="1.0" encoding="UTF-8" ?> <data> <log value="Chip serial num: 4294967295 (0xffffffff)"/> </data><?xml version="1.0" encoding="UTF-8" ?> <data> <log value="Supported Functions: program configure nop firmwarewrite patch setbootablestoragedrive ufs emmc power benchmark read getstorageinfo getsha256digest erase peek poke "/> </data> Programming device using SECTOR_SIZE=512 <?xml version = "1.0" ?><data><configure MemoryName="emmc" ZLPAwareHost="1" SkipStorageInit="0" SkipWrite="0" MaxPayloadSizeToTargetInBytes="1048576"/></data> <?xml version="1.0" encoding="UTF-8" ?> <data> <log value="Calling usb_al_bulk_set_zlp_mode(TRUE) since ZlpAwareHost='1'"/> </data> <?xml version="1.0" encoding="UTF-8" ?> <data> <log value="Calling hotplug_poll_device('MMC')"/> </data> <?xml version="1.0" encoding="UTF-8" ?> <data> <log value="Storage device of type 'MMC' cannot be opened"/> </data> <?xml version="1.0" encoding="UTF-8" ?> <data> <log value="storage_device_open() returned FALSE"/> </data> <?xml version="1.0" encoding="UTF-8" ?> <data> <log value="ERROR 13: Line 1142: HANDLE_CONFIGURE_FAILURE"/> </data> <?xml version="1.0" encoding="UTF-8" ?> <data> <response value="NAK" /> </data> ---Target returned NAK--- | |
01-29-2018, 23:28 | #9 (permalink) | |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Quote:
Code: <data> <log value="Storage device of type 'MMC' cannot be opened"/> </data> <?xml version="1.0" encoding="UTF-8" ?> <data> <log value="storage_device_open() returned FALSE"/> </data> | |
