Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 09-09-2017, 03:16   #1 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,836
Need Lenova a6600d40 frp solution ?
Hello guyz
Got lenova a6600d40 for frp removed tried all free method ( test dpc , frp bypass apk ) all method fail .. any other solutions ?
Thank you
Old 09-10-2017, 23:21   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 5,082
Okay, here's the solution ...
Download needed stuff : Lenovo_A6600D40_S325_1704051331_FRP_Remove_by_bRkA
archive pass: forum.gsmhosting.com
- Unpack, Start SPFT
- Select Download Agent - DA_SWSEC_CRYPTO20_0217.bin
- Load scatter file - MT6735M_Android_scatter.txt
- Go to tab FORMAT, select "validation", select "manual format"
- Input start address : 0x6a00000 , length : 0x100000
- Press START button, connect powered off device to cable, wait for finish.
- Boot phone into recovery menu - wipe data/factory reset, then reboot
- FRP should be gone.
If you get on screen "Tool DL Image failed" od "DL Image failed",
simply reflash device with A6600D40_S325_1704051331 ROM.
Use SPFlashTool from first link, same procedure with DA Agent,
just use scatter from second link.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 9 Users Say Thank You to Brka For This Useful Post:
Old 09-11-2017, 13:15   #3 (permalink)
Member: 185705
Thanks Meter: 7
thank you vey much for
A6600D40
Old 09-16-2017, 03:49   #4 (permalink)
swapan's Avatar
Member: 330460
Sonork: 100.1655426 QQ:3197829913
Thanks Meter: 5,801
Smile Lenovo A6600d40 MT6735M Frp Reset Done
The Following 5 Users Say Thank You to swapan For This Useful Post:
Page generated in 0.18549 seconds with 7 queries
