Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 02-05-2017, 15:21   #16 (permalink)
Member: 1721679
need firmware for lenovo a1000_USR_S30310_1608191008_SPRD7731_RO
Old 02-05-2017, 22:28   #17 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,403
It's not latest firmware, but anyway,
download - A1000_Dual_SIM_S30310_160819_ROW (Dual Sim, Android 5.x, ROW).
p.s.
Latest firmwares are :
A1000_SS_S30571_161111_ROW (SingleSIM, Android 5.x, ROW)
and
A1000_Dual_SIM_S30666_161121_ROW (Dual Sim, Android 5.x, ROW)
Originally Posted by gsmview.11 View Post
umm....i downloaded both files and asked someone more proficient than i am on flashing this file. but no success, had this firmware been tested? any out there who can refer us to a new link?
It goes this way (for Lenovo A1000)
- Download SPRD Drivers and A1000 Flash Tools, unpack, install drivers (32 or 64bit),
- Also download Firmware you want to flash (look above, i posted latest firmware), unpack it
- Start UpgradeDownload (Flasher),
- Press a little cogwheel icon in upper-left corner of flasher, and select firmware with extension .pac
- Press "Play" (Start) button
- On powered off phone, hold Volume UP and while holding, insert usb cable
- It will start flashing, and at the end display "passed"
- Press "Stop" button, and close the flasher
- Start your phone and be patient, because first start could take some longer time.
Video instructions can be found - HERE
archive pass (if needed): lenovo-forums.ru
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 11 Users Say Thank You to Brka For This Useful Post:
Old 02-17-2017, 05:48   #18 (permalink)
Member: 1272849
Thanks Meter: 11
please pasword firm a1000 30366 dual sim thxs
Old 02-20-2017, 23:36   #19 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,403
all my uploads, which ask for password,
pass : lenovo-forums.ru
b.r.
Alex
__________________
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 02-26-2017, 22:30   #20 (permalink)
Member: 2689501
[Help] A1000 - UpgradeDownload Failure
I've had this new phone for some weeks and it is only locked to one certain network so I wanted to flash it and luckily there were too many tutorials online so I just followed them but I've been stuck trying to find a solution for hours so I decided to come ask here maybe someone can help me.
Pic - http : //imgur. com/a/lcMqT (remove space because I'm new)
Problem - Failed: User Cancel
Phone - A1000*
Notice - When I plug the charger and the phone is off it goes to a charging screen automatically
Btw, I've tried like 10 other versions of this software. Some even had more problems but the ones that worked had this same problem.
Any help is appreciated, ty.
Old 02-26-2017, 22:37   #21 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,403
Now read thread from beginning. All needed files are here.
To connect phone in flash mode, start flashing process,
hold VOLUME UP key and insert usb cable into phone.
Spreadtrum drivers should be installed as first step, of course.
p.s. If you are using retarded Windows 10 or Windows 8/8.1, find some pc with normal Windows 7, and retry process.
b.r.
Alex
__________________
Old 03-29-2017, 09:44   #22 (permalink)
Member: 2619617
the file does'nt found. Error 404
any other correct link ????????????????????????
Old 03-30-2017, 03:30   #23 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,403
Removed expired links from first post.
You have full pack in post #19.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 04-30-2017, 17:21   #24 (permalink)
Member: 1054358
Sonork: 100.1626312
Thanks Meter: 230
password: lenovo-forums.ru
Old 05-01-2017, 13:00   #25 (permalink)
Member: 2712559
Hi all how are you
I have a problem with a possible upload with someone help me
Old 07-17-2017, 11:22   #26 (permalink)
Member: 190274
Thanks Meter: 40
Thanks for the awesome links. Sadly i have been unable to fix my dead one. Its completely dead after imei repair. Flashing with all the firmware and writing nvm has had no effects Flashing is successful but phone never boots. It is the dual sim model. Any ideas what to do?
Old 07-18-2017, 03:09   #27 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,403
A1000 Dual SIM ROM :
A1000_Dual_SIM_S30666_161121_ROW (For Ukraine)
archive pass : lenovo-forums.ru
b.r.
Alex
__________________
Old 07-18-2017, 09:19   #28 (permalink)
Member: 190274
Thanks Meter: 40
b.r.
Alex
I will try it and give feedback asap. Thanks so much
Old 07-18-2017, 09:27   #29 (permalink)
lathik's Avatar
Member: 2199277
Sonork: 100.1678358
Thanks Meter: 159
https://firmwarefile.com/lenovo-ideatab-a1000-f
Old 07-18-2017, 10:51   #30 (permalink)
Member: 190274
Thanks Meter: 40
Originally Posted by lathik View Post
Unfortunately the firmware i need is not the tab, but the dual sim phone. Thanks anyway
Page generated in 0.40629 seconds with 7 queries
