Lenovo General Lenovo phones discussion, firmwares, solution, help |
09-05-2017, 21:40 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
Now, can you enter recovery ? (powered off device, volume UP + power on) If yes ... Download : P2c72_USR_ST1637_5.805.1_1609111948_Q10000_CN archive pass : lenovo-forums.ru Unpack, you should get another zip file, rename it to update.zip, copy to sd-card, insert in phone, enter recovery and do "install update from sdcard" (or external sd-card). Wait for finish, then wipe data/factory reset, then reboot device. After that it should boot up. If no recovery ... that's bad. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
09-06-2017, 13:38 | #3 (permalink) |
Junior Member Join Date: Oct 2005
Member: 189692 Status: Offline Thanks Meter: 7 | Hello!! Thank you, but It is not working. It start to update the system but gets a fail, I tried a lot of times but I did not get any solution to fix it. Thank you for your solution anyway |
09-06-2017, 18:15 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Possible hardware problem (flash memory malfunction). Only thing left, is making efs/qcn + baseband (modemst1+2) bqckup, And to reflash into row model. If that also fails... Then 100% hardware problem. B.r. Alex
