05-24-2016, 08:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | A11_UL Flash not successfull, reboot will not be done target rom version: 1.08.206.1 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (41217 KB)... OKAY [ 2.668s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... Processing [hboot], please wait... (bootloader) total_image_number=8 Processing [hboot], please wait... (bootloader) ...... Successful (bootloader) current_image_number=0 Processing [sbl1], please wait... Processing [sbl1], please wait... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=1 (bootloader) current_image_number=2 (bootloader) current_image_number=3 Processing [rpm], please wait... Processing [rpm], please wait... (bootloader) ...... Successful (bootloader) current_image_number=4 Processing [tz], please wait... Processing [tz], please wait... (bootloader) ...... Successful (bootloader) current_image_number=5 Processing [hyp], please wait... Processing [hyp], please wait... (bootloader) ...... Successful (bootloader) current_image_number=6 (bootloader) current_image_number=7 FAILED (remote: 90 hboot pre-update! please flush image again immediately) finished. total time: 5.179s preupdate done, rebooting... Phone DISconnected Phone connected [CC4BEY402900] *** Fastboot mode resending command... sending 'zip' (41217 KB)... OKAY [ 2.621s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) total_image_number=7 Processing [sp1], please wait... (bootloader) ...... Successful (bootloader) current_image_number=0 Processing [pg2fs_spcustom], please wait... (bootloader) ...... Successful (bootloader) current_image_number=1 Processing [wcnss], please wait... (bootloader) ...... Successful (bootloader) current_image_number=2 Processing [tp], please wait... (bootloader) ..... Bypassed (bootloader) current_image_number=3 Processing [recovery], please wait... (bootloader) ...... Successful (bootloader) current_image_number=4 Processing [radio], please wait... (bootloader) trying to rename MBA (bootloader) ...... Successful (bootloader) current_image_number=5 Processing [rcdata], please wait... (bootloader) ...... Successful (bootloader) current_image_number=6 OKAY [ 18.581s] finished. total time: 21.201s processing file 2/7... sending 'zip' (390882 KB)... OKAY [ 15.366s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) shift signature_size for header checking... FAILED (remote: 32 header error) finished. total time: 16.318s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done try this flash file 0PCVIMG_A11_UL_K44_DESIRE_SENSE60_AIO_Globalive_WW E_1.17.1500.2_Radio_1.101.1372.19.0918_10.24.4205. 00L_release_394717_signed_2_4 0PCVIMG_A11_UL_K443_DESIRE_SENSE60_HTC_WWE_Tesco_1 .09.1107.7_Radio_01.02.010_U10251_37.08.40820_rele ase_459264_signed_2_4 0PCVIMG_A11_UL_K443_DESIRE_SENSE60_O2_UK_1.08.206. 1_Radio_01.02.010_U10251_36.08.40814_release_38871 8_signed_2_4 |
05-25-2016, 09:54 | #3 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | i think u r problem is allready sloved , ignore this remote: 32 header error reboot will not be done,after flash just manuali put phone in bootloder mode by useing bootloder option in xtc2 exe, and select reboot phone becoz one time few days ago i m also faceing this error in flashing but after flash i manuali reboot phone, that time my problem was solved....but bro i m not sure that u r problem will be solve or not, just try this way,other wise wait 4 xtc2 reply |
05-26-2016, 06:39 | #4 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
05-30-2016, 13:32 | #7 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | If your phone can't be flashed, it's most likely an EMMC issue. Because we have checked the files and they are correct. The only thing you can try is SD method - if it will fail in the middle as direct flashing - it's hardware issue. Last edited by xtc2clip; 05-30-2016 at 13:38. |
05-31-2016, 08:56 | #9 (permalink) |
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | SD (offline) method.copy rom.zip to the sd-card and rename it to 0PCVIMG insert it to your mobile, boot your mobile into bootloader mode,by pressing p.off+vol down it vil start the flashing automatically......... |
