10-20-2018, 09:10 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: iran
Member: 2497933 Status: Offline Thanks Meter: 7 | a52_dtul imei repair problem [SOLVED] I need to change imei for a52_dtul . Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.0.U20410.1@60201 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.10.401.3 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HT5CSYG00322 (bootloader) imei: 357290069024038 (bootloader) imei2: 357290069024046 (bootloader) meid: 00000000000000 (bootloader) product: a52_dtul (bootloader) platform: hTCBmsm8939 (bootloader) modelid: 0PHC10000 (bootloader) cidnum: HTC__J15 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 87c55d84 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 1001 all: Done! Execution time is 12(ms) Reading CID information ... (bootloader) cid: HTC__J15 OKAY Execution time is 4(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 5(ms) Reading IMEI1 information ... (bootloader) imei: 357290069024038 OKAY Execution time is 5(ms) Reading IMEI2 information ... (bootloader) imei2: 357290069024046 OKAY Execution time is 5(ms) Reading secure flag information ... (bootloader) secure_flag: 3 OKAY Execution time is 4(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 4(ms) Reading color information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 6(ms) Read information completed. Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 7 (bootloader) a52dtul_init_sd, SD card already power on (bootloader) a52dtul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 1773420032 (bootloader) erase_grpmult: 49152 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [SD_ERR] sd_read_sector: read sector failed (778135908 1) (bootloader) [Tuxera][Error] Primary partition 0 (778135908/1141509631): (bootloader) failed to read sector #778135908 (bootloader) [SD_ERR] sd_read_sector: read sector failed Operation finished |
10-20-2018, 09:48 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | can u try sd mode for s-off ? either phone did not detect clip or you need to repair filesystem |
The Following User Says Thank You to deepakgarg For This Useful Post: |
10-20-2018, 10:13 | #3 (permalink) | |
Member: 2497933 Status: Offline Thanks Meter: 7 | Quote:
yes I tried but this error: | |
