12-06-2017, 13:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Poland Age: 39
Member: 219917 Status: Offline Thanks Meter: 60 | A9s FTM problem I have try Imei repair in A9s model, but without success Clip have repaired File System, in special/unlock tab I have set new IMEI and save file to clip. Clip is connectet to phone, but every time I try to reboot to FTM via clip aplplication or buttons this message appear: "reboot to ftm failed due to VERIFY-FAIL" |
12-06-2017, 15:04 | #3 (permalink) |
Member: 219917 Status: Offline Thanks Meter: 60 | It's about A9, not A9s. 2 different modells. I have S-Off phone and then run FTM. IMEI is changed, but partially. System show new one, download-mode and program show still old. Any idea? |
The Following User Says Thank You to kwaku85 For This Useful Post: |
12-06-2017, 16:36 | #4 (permalink) |
Member: 219917 Status: Offline Thanks Meter: 60 | I have check all options, with Power Adapter, with original XTC2Clip card, all possible combinations. Looks S-Off is required to change IMEI, but even with S-Off can be changed only system IMEI. Bottloader IMEI stay same. |
12-06-2017, 23:45 | #6 (permalink) |
Member: 219917 Status: Offline Thanks Meter: 60 | I have try all methods, change is probably not possible. Direct comands not work- it's MTK model. FTM mode need S-Off, but even with removed security- IMEI will be changed only on system, bootloader IMEI remain this same. I spend whole day trying all possible combinations. Without success. |
12-07-2017, 19:06 | #7 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
I will look into this problem and let you know. | |
