01-20-2018, 16:00 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Age: 37
Member: 906256 Status: Offline Thanks Meter: 40 | htc e8 s-off error [SOLVED] Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.24.30306251.15G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 3.07.425.1 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HC56KWY01672 (bootloader) imei: 35723006******* (bootloader) imei2: 35723006******* (bootloader) meid: 00000000000000 (bootloader) product: mec_dugl (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0PAJ20000 (bootloader) cidnum: HTC__059 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 5c9466dd (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 11(ms) Reading CID information ... (bootloader) cid: HTC__059 OKAY Execution time is 😔ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 2(ms) Reading IMEI1 information ... (bootloader) imei: 357230062366499 OKAY Execution time is 😔ms) Reading IMEI2 information ... (bootloader) imei2: 357230062366507 OKAY Execution time is 2(ms) Reading secure flag information ... (bootloader) secure_flag: 3 OKAY Execution time is 2(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 2(ms) Read information completed. direct mode Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) mecdugl_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078040 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [SD_ERR] sd_read_sector: read sector failed (778135908 1) (bootloader) [Tuxera][Error] Primary partition 0 (778135908/1141509631): (bootloader) failed to read sector #778135908 (bootloader) [SD_ERR] sd_read_sector: read sector fai Operation finished can"t s-off plz help |
