Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 10-13-2016, 09:18   #1 (permalink)
mike_shinoda's Avatar
Member: 2136780
Thanks Meter: 68
can not flash htc 10
hello
i have htc 10 when power on phone go to fastboot mode
when flash show write error
Starting flash process...
target rom version: 1.17.1405.8
found large-zip header, file count: 20
processing file 1/20...
sending 'zip' (254721 KB)...
OKAY [ 13.201s]
writing 'zip'...
(bootloader) HOSD CL#750539
Process Process-1:
Traceback (most recent call last):
File "C:\Python34\lib\multiprocessing\process.py", line 254, in _bootstrap
File "C:\Python34\lib\multiprocessing\process.py", line 93, in run
File "E:\largezip\htc_fastboot\htc_flashzip.py", line 207, in _do_extract
File "E:\largezip\htc_fastboot\rompack.py", line 49, in extract
File "C:\Python34\lib\zipfile.py", line 1118, in read
File "C:\Python34\lib\zipfile.py", line 749, in read
File "C:\Python34\lib\zipfile.py", line 833, in _read1
File "C:\Python34\lib\zipfile.py", line 863, in _read2
FileNotFoundError: [Errno 2] No such file or directory
FAILED (remote: 9 RU_SECURITY_FAIL zip from usb command in download mode)
finished. total time: 14.215s
Flash process completed.
Flash not successfull, reboot will not be done
info phone
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_pmec2tuhl
(bootloader) version: 1.0
(bootloader) imei: 354882070068575
(bootloader) version-main: 1.17.1405.8
(bootloader) boot-mode: download
(bootloader) version-baseband: 1.0.U130.1@60415G_2
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PS630000
(bootloader) cid: HTCCN701
all:
Execution time is 9(ms)
Reading secure flag information
... (bootloader) Device security level S-ON
OKAY
Execution time is 15(ms)
Reading CID information
... (bootloader) cid: HTCCN701
OKAY
Execution time is 12(ms)
Reading MEID information
... (bootloader) meid:
OKAY
Read information completed.
flash this file
2PS6IMG_PERFUMEC2_TUHL_M60_SENSE80GP_HTCCN_CHS_2_1.17.1405.8_Radio_1.0.U130.1.60415G_2_01.00F_release_479231_signed_2_4
Old 10-13-2016, 16:47   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
When the phone is S-ON, you must flash in RUU mode (use RUU button in XTC 2 Tool to switch).
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 10-13-2016, 18:03   #3 (permalink)
Member: 2242680
Sonork: Skype: mr.thuan92
Thanks Meter: 157
Smile
Originally Posted by mike_shinoda View Post
hello
Flash not successfull, reboot will not be done[/CODE]
info phone
(bootloader) imei: 354882--
all:
OKAY
OKAY
OKAY
flash this file
2PS6IMG_PERFUMEC2_TUHL_M60_SENSE80GP_HTCCN_CHS_2_1 .17.1405.8_Radio_1.0.U130.1.60415G_2_01.00F_releas e_479231_signed_2_4
-copy RUU HTC 10 Lifestyle 2PS6IMG_PERFUMEC2_TUHL_M60_SENSE80GP_HTCCN_CHS_2_1.17.1405.8_Radio_1.0.U130.1.60415G_2_01.00F_release_479231_s igned_2_4.zip
to sd card
-rename =2PS6IMG.zip, then boot to Download mode, volum up.. flash.. ok
Old 10-13-2016, 18:05   #4 (permalink)
Member: 2242680
Thanks Meter: 157
-unlock bootloader, twrp (?)
-s-off by xtc2clip box
-write cid 11111111
-flash RUU
PERFUMEC2_TUHL Marshmallow 6.0 / SENSE80GP HTC Europe 1.16.401.3
Radio 1.0.U130.1.60325G 477970
World Wide English
MD5: 4e881d22936e38c8c5f9c77e71b5792e HTC__001, HTC__J15, HTC__034, HTC__A07, HTC__002 2PS630000 1.82GB
2PS6IMG_PERFUMEC2_TUHL_M60_SENSE80GP_HTC_Europe_1. 16.401.3_Radio_1.0.U130.1.60325G_release_477970_si gned_2_4.zip
(CH PLAY ok, remove China app)
_good luck
The Following User Says Thank You to thuanmobile896 For This Useful Post:
Old 10-23-2017, 15:11   #5 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
-write cid 11111111
-flash RUU
World Wide English
_good luck
how u do s-off please bro
i treid try but unsuccsessfull boot in to twrp
Old 10-23-2017, 15:17   #6 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
Originally Posted by xtc2clip View Post
Hello,
my master i try to boot in twrp after write recovery but failed to boot
C:\adb>fastboot flash recovery "D:\HTC\htc 10u\twrp3.0.2.0\twrp-3.0.3-0_UNOFFICIAL-pme.img"
target reported max download size of 800000000 bytes
sending 'recovery' (54556 KB)...
OKAY [ 3.540s]
writing 'recovery'...
(bootloader) start@1
(bootloader) recovery@100%
(bootloader) Update partition OK
(bootloader) end@Done
OKAY [ 3.437s]
finished. total time: 6.982s
model is
the faield massage is
Old 10-25-2017, 14:56   #7 (permalink)
Member: 1990913
Thanks Meter: 21
https://androidfilehost.com/?fid=673368273298928916
had similar issues. use the ruu above
Page generated in 0.16713 seconds with 9 queries
