can t change cid in htc u11 plus Hello! I can t change cid in HTC U11 Plus with fast mode or recovery method. Any idea? Thanks! |
what error you got ?? |
Starting PowerAdapter procedure: Special recovery file is available 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Rebooting to boot-loader: Waiting for the phone... Phone DISconnected Phone connected [FA7CB1E00379] *** Fastboot mode Executing operation... Starting operation... Operation completed! Releasing adapter. Request completed This is in fast mode but the CID is the same. And in recovery mode when the program says to enter in recovery mode manually, the phone restarts. |
power adapter and phone must be connected via direct usb do not use any hub please try once more |
still the same, operation succesfully but the cid is the same |
I want to flash firmware from another region because europe firmware has bugs, even if the phone is not in airplane mode, you have no service and when you want to call, the phone says it is in airplane mode. |
