04-27-2016, 19:27 | #16 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Connect clip to SD slot, boot to download mode (PWR+VOL DOWN), make sure that you don't get "SD NOT MOUNTED" message and do master reset. That's all. |
04-27-2016, 19:40 | #17 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Dallas, Texas, USA
Member: 1693475 Status: Offline Thanks Meter: 12 | Ok, its seeing the phone now, press the soff button, but get this: (bootloader) ERR commad error !!! Execustion time is 3268MS OKAY operation finished and it did not take it off. if i goto frp removal, it says soff is still on. |
05-02-2016, 17:55 | #19 (permalink) |
Member: 1693475 Status: Offline Thanks Meter: 12 | ok, i have the phone in download mode now, with SIM clip attached to phone and micro usb from computer to phone. when i press the 'clear sim lock' button the command line box reads 'sending oem clearsimlocktype' and just hangs. nothing happens, after waiting 10 minutes |
05-02-2016, 17:57 | #21 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
05-02-2016, 18:27 | #24 (permalink) |
Member: 1693475 Status: Offline Thanks Meter: 12 | ok, and it can handle both phones like the 626 which use code, and the 626s which uses the device unlock app ? can you forward instructions on sim unlocking ? thanks for the help! |
05-11-2016, 14:54 | #26 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: india
Member: 368923 Status: Offline Thanks Meter: 85 | htc d626x frp lock Quote:
Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 5 (bootloader) a32dcgl_init_sd, SD card already power on (bootloader) a32dcgl_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 3 (bootloader) erase_grpmult: -1921008668 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [SD_ERR] sd_read_sector: read sector failed (778135908 1) (bootloader) [Tuxera][Error] Primary partition 0 (778135908/1141509631): (bootloader) failed to read sector #778135908 (bootloader) [SD_ERR] sd_read_sector: read sector failed (1 68689522 1) (bootloader) [Tuxera][Error] Primary partition 1 (168689522/1936028240): (bootloader) failed to read sector #168689522 (bootloader) [SD_ERR] sd_read_sector: read sector failed (1869881465 1) (bootloader) [Tuxera][Error] Primary partition 2 (1869881465/1936028192): (bootloader) failed to read sector #1869881465 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [FAT_ERROR] FAT12 is not supported! (bootloader) [FAT_ERROR] FAT12 is not supported! (bootloader) [FAT_ERROR] fat_open_file: can not find SMART_IO.CRD (bootloader) [JAVACARD_ERR] SMART_IO.CRD cann't find (bootloader) writesecureflag: Permission denied, value 1 OKAY Execution time is 1(s) Operation finished | |
05-11-2016, 15:36 | #30 (permalink) |
Member: 368923 Status: Offline Thanks Meter: 85 | hi xtc team, pls help me to make s-off htc d626x.i made setting in sd mode editor 0-security off (s-off) and save to drive. then attached the clip strip in to phone memory card slot. on pressing volume down and power button connect the phone in fastboot usb mode and press direct command mode . but no success.pls help me, what is wrong with me. br sunnny |
