06-14-2019, 11:29 | #1 (permalink) |
Junior Member Join Date: Jan 2006
Member: 218681 Status: Offline Thanks Meter: 1 | clip problem ... (bootloader) SecuritySDInit: counter = 4 (bootloader) a32dcgl_init_sd, SD card already power on (bootloader) a32dcgl_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: -1921008668 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 (bootloader) writesecureflag: Permission denied, value 4 OKAY Execution time is 2(s) Operation finished Phone DISconnected post:[email protected] |
06-14-2019, 14:07 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
please clean and reinsert smart card or check flex as well than try again same error might mean smart card needs replacement | |
