09-20-2016, 16:07 | #1 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,163 | Clip problems - READ FIRST, Click for support If you are having a problem with your clip, please read this first, this guide will help you save your time and help us to assist your quicker. Tools used in this guide: Win32Disk imager to "repair filesystem" : http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ Possible errors: Clip communication error X, Cannot open smart_io.crd If you are getting this error, it means that there was a problem in communication with the clip. Possible reasons: - File system failure. Solution: Repair filesystem(see above) - Flex failure. Solution: Replace flex: http://xtc2.net/downloads/replace_flex.jpg DECREASE_CYCLE_FAILED: If you have this error, you have to follow this procedure: - Connect your XTC 2 Clip to PC - Run XTC 2 Client (NOT Tool, Client, which is used for activation/registration) - Click "Next" - After this send me a PM or email with your clip ID. Check keycard failed: If you are getting this message when using Y-cable (for example with M7 phone), then first you have to try another Y-cable and ANOTHER microSD reader (yes, even if this reader worked on another phone, still try another). If you get this message with direct usage via microSD slot, please do this: - Connect your XTC 2 Clip to PC - Run XTC 2 Client (NOT Tool, Client, which is used for activation/registration) - Click "Next" - After this send me a PM or email with your clip ID. Windows is asking to format my disk: Possible problems are damaged flex and/or faulty microSD reader. Solution: replace flex, change microSD reader and do filesystem repair. I have formatted my clip in Windows: Please use filesystem repair option, as windows format may not be good for many phones. |
The Following 9 Users Say Thank You to xtc2clip For This Useful Post: |
11-08-2016, 23:59 | #2 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2612601 Status: Offline Thanks Meter: 20 | Cannot open smart_io.crd error. win32 wouldn't work so i found an alternative. Gives error #158 occured white writing to disk sector 0. Format clip then it allowed to write successfully but still same error when trying to run software. I was able to activate fine. Tried multiple flex cables. |
11-09-2016, 19:36 | #3 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,163 | Quote:
Please try to change your microSD reader. | |
12-28-2016, 15:30 | #7 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1463180 Status: Offline Thanks Meter: 0 | XTC 2 Clip is not found A few days ago I got the xtc2clip and tried all the steps described in the different posts of the forum but I could not activate always shows error: XTC 2 Clip is not found I have tried in: Several different pc Several microsd readers I got an intelligent card I do not know what to do, please help. Greetings, |
01-18-2017, 16:24 | #13 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,163 | |
