07-13-2017, 07:20 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | correct rom please Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.0.U20410.1@60330C (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.10.709.2 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: CC57HYM05505 (bootloader) imei: 357249061799534 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: a32_ul (bootloader) platform: hTCBmsm8916 (bootloader) modelid: 0PKX21000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (bootloader) commitno-bootloader: 0b9a12e3 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 1001 all: Done! Execution time is 24(ms) Reading secure flag information ... (bootloader) secure_flag: 0 OKAY Execution time is 20(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 19(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 20(ms) Read information completed. Phone DISconnected |
07-17-2017, 06:58 | #3 (permalink) |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Starting flash process... target rom version: 1.10.709.2 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (40895 KB)... OKAY [ 2.893s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... FAILED (remote: 24 parsing android-info fail) finished. total time: 3.307s Flash process completed. error with that file |
07-20-2017, 13:02 | #7 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
As I see, your version is very old (one of the first), dated 2015. I'd recommend you to flash something newer, like 428058 or 447583. Or, better even latest 481499 (which has Android 6) | |
07-20-2017, 13:15 | #8 (permalink) | |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | with new version error 54 Starting flash process... found large-zip header, file count: 7 processing file 1/7... sending 'zip' (98386 KB)... OKAY [ 4.996s] writing 'zip'... (bootloader) zip header checking... (bootloader) shift signature_size for header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... Processing [hboot], please wait... (bootloader) total_image_number=12 Processing [hboot], please wait... (bootloader) ...... Successful (bootloader) current_image_number=0 Processing [sp1], please wait... (bootloader) ...... Successful (bootloader) current_image_number=1 Processing [tz], please wait... (bootloader) ...... Successful (bootloader) current_image_number=2 Processing [rpm], please wait... (bootloader) ...... Successful (bootloader) current_image_number=3 Processing [pg2fs_spcustom], please wait... (bootloader) ...... Successful (bootloader) current_image_number=4 Processing [wcnss], please wait... (bootloader) ...... Successful (bootloader) current_image_number=5 Processing [hyp], please wait... (bootloader) ...... Successful (bootloader) current_image_number=6 Processing [sbl1], please wait... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=7 Processing [recovery], please wait... (bootloader) ...... Failed (bootloader) current_image_number=8 Processing [boot], please wait... (bootloader) ...... Failed (bootloader) current_image_number=9 Processing [radio], please wait... (bootloader) trying to rename MBA (bootloader) ...... Successful (bootloader) current_image_number=10 Processing [rcdata], please wait... (bootloader) ...... Successful (bootloader) current_image_number=11 FAILED (remote: 54 image size is too large) finished. total time: 18.082s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done phone info Quote:
07-21-2017, 06:24 | #10 (permalink) | |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
07-21-2017, 06:54 | #11 (permalink) |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | with 428058 Starting flash process... target rom version: 1.01.707.3 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (40892 KB)... OKAY [ 2.870s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... FAILED (remote: 22 loading zip info fail Please check if you flash par) finished. total time: 3.292s |
07-26-2017, 10:29 | #15 (permalink) | |
It's very strange in fact. Well, I can suggest you to flash TWRP, and try to flash image from another phone via TWRP (I think you can find it on the internet). You also said that it's "stuck in fastboot mode", but partial upgrades both fastboot and recovery images, so if it hangs even after successfull flash of partial flash file, I think you should check hardware first. | |
