04-28-2018, 11:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: colombo
Member: 399781 Status: Offline Thanks Meter: 94 | d728h FAILED (remote: 10: fail to flash via downloadzip) target rom version: 1.08.401.3 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (41705 KB)... OKAY [ 4.742s] writing 'zip'... (bootloader) HOSD CL#647213 (bootloader) GPT is up-to-dated. [524288] (bootloader) Perform pre-update (bootloader) start@14 (bootloader) tee1.img@100% (bootloader) tee2.img@100% (bootloader) preloader.bin@100% (bootloader) pg2fs_ship_signkey.img@BYPASS (bootloader) apppreload.img@BYPASS (bootloader) secro_verified.img@100% (bootloader) cota.img@BYPASS (bootloader) tp_HMX852XE_SECOND.img@BYPASS (bootloader) tp_HMX852XE_MAIN.img@BYPASS (bootloader) lk_verified.bin@100% (bootloader) hosd_verified.img@100% (bootloader) boot_verified.img@BYPASS (bootloader) recovery_verified.img@BYPASS (bootloader) logo_verified.bin@100% (bootloader) Perform hardware reset FAILED (remote: 90 hboot pre-update! please flush image again immediately) finished. total time: 7.051s preupdate done, rebooting... Phone DISconnected resending command... < waiting for device > sending 'zip' (41705 KB)... OKAY [ 5.788s] writing 'zip'... (bootloader) HOSD CL#647213 (bootloader) GPT is up-to-dated. [524288] (bootloader) start@14 (bootloader) tee1.img@100% (bootloader) tee2.img@100% (bootloader) preloader.bin@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) apppreload.img@50% (bootloader) apppreload.img@100% (bootloader) secro_verified.img@100% (bootloader) cota.img@100% (bootloader) lk_verified.bin@100% (bootloader) hosd_verified.img@100% (bootloader) boot_verified.img@100% (bootloader) recovery_verified.img@100% (bootloader) logo_verified.bin@100% (bootloader) tp_HMX852XE_SECOND.img@20% (bootloader) tp_HMX852XE_SECOND.img@75% (bootloader) tp_HMX852XE_SECOND.img@100% (bootloader) tp_HMX852XE_SECOND.img@100% (bootloader) tp_HMX852XE_MAIN.img@BYPASS (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 24.164s] finished. total time: 29.952s processing file 2/7... sending 'zip' (342304 KB)... OKAY [ 32.682s] writing 'zip'... (bootloader) HOSD CL#647213 (bootloader) start@1 (bootloader) ERR P_partition_format: Discard failed, ret(-1), range[0-30 (bootloader) 87007744] (bootloader) system.img_00@11% (bootloader) system.img_00@23% (bootloader) system.img_00@34% (bootloader) system.img_00@46% (bootloader) system.img_00@57% (bootloader) system.img_00@69% (bootloader) system.img_00@80% (bootloader) system.img_00@92% (bootloader) system.img_00@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 61.714s] finished. total time: 94.396s processing file 3/7... Phone connected [LC5BPZ702037] *** Fastboot mode sending 'zip' (343132 KB)... OKAY [ 32.354s] writing 'zip'... (bootloader) HOSD CL#647213 (bootloader) ERR Model ID not matched (bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP ERROR, exit read zip loop (bootloader) ERR [SEC] sd_get_pg2fs_sign_key: read pg2fs partition faile (bootloader) ERR [SEC] sd_is_signature_okay: get sign key failed (bootloader) ERR ZIP signature checking failed... (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 10 (bootloader) end@Done FAILED (remote: 10: fail to flash via downloadzip) finished. total time: 48.235s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done |
04-28-2018, 11:52 | #3 (permalink) |
Member: 399781 Status: Offline Thanks Meter: 94 | 4/28/2018 2:49:19 PM Read information completed. 4/28/2018 2:49:19 PM Connecting to the server... 4/28/2018 2:49:21 PM Done. Please continue in your browser 4/28/2018 2:50:39 PM Phone DISconnected 4/28/2018 3:27:48 PM Phone connected [LC5BPZ702037] *** Fastboot mode 4/28/2018 3:27:51 PM Reading information... 4/28/2018 3:27:51 PM Using Fastboot mode... 4/28/2018 3:27:51 PM Reading common information 4/28/2018 3:27:52 PM (bootloader) kernel: lk (bootloader) product: htc_a50cmg_dwg (bootloader) version: 1.0 (bootloader) imei: 351583070510045 (bootloader) version-main: 1.08.401.3 (bootloader) boot-mode: download (bootloader) version-baseband: READ version-baseband ERROR (bootloader) version-bootloader: 1.01.0000 (bootloader) mid: 2PQ830000 (bootloader) cid: HTC__J15 all: Execution time is 15(ms) 4/28/2018 3:27:52 PM Reading CID information 4/28/2018 3:27:52 PM ... (bootloader) cid: HTC__J15 OKAY Execution time is 46(ms) 4/28/2018 3:27:52 PM Reading MEID information 4/28/2018 3:27:52 PM ... FAILREAD MEID ERROR FAILED (remote: READ MEID ERROR) Execution time is 15(ms) 4/28/2018 3:27:52 PM Reading IMEI1 information 4/28/2018 3:27:53 PM ... (bootloader) imei: 351583070510045 OKAY Execution time is 15(ms) 4/28/2018 3:27:53 PM Reading IMEI2 information 4/28/2018 3:27:53 PM ... FAILREAD IMEI2 ERROR FAILED (remote: READ IMEI2 ERROR) Execution time is 15(ms) 4/28/2018 3:27:53 PM Reading secure flag information 4/28/2018 3:27:53 PM ... (bootloader) Device security level S-ON OKAY Execution time is 0(ms) 4/28/2018 3:27:53 PM Reading serial number information 4/28/2018 3:27:54 PM ... (bootloader) Device Serial No. is LC5BPZ702037 OKAY Execution time is 0(ms) |
04-28-2018, 15:50 | #5 (permalink) | |
Freak Poster Join Date: Jun 2013 Location: india tirupur tamilnadu
Member: 1962832 Status: Offline Thanks Meter: 199 | Quote:
frnd flash via sd card metd: https://mega.nz/#!uBIERRaK!XBM-PKY8o...p0ZI4DTPMFxA9A | |
04-28-2018, 16:34 | #6 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
05-03-2018, 13:29 | #8 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | if partition updates failed could be flash file problem or emmc problem |
The Following User Says Thank You to deepakgarg For This Useful Post: |
