01-31-2017, 20:56 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, First S-OFF using "S-OFF" tab (you need to unlock bootloader first, you can do it if it's not a Verizon phone), and then repair IMEI in download mode using "Direct mode commands" tab. |
02-01-2017, 08:34 | #3 (permalink) |
Freak Poster Join Date: Sep 2016 Location: ljubljana
Member: 2622097 Status: Offline Thanks Meter: 22 | i did S-OFF , but when i go to direct mode to repair imei i get this : Sending oem clearsimlocktype ... (bootloader) [ERR] Command error !!! OKAY Execution time is 66(ms) Operation finished |
02-01-2017, 10:15 | #5 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
So please decide what are you trying to do, and why are you seeking for "sim lock" option in the recovery... | |
02-01-2017, 11:44 | #6 (permalink) |
Member: 2622097 Status: Offline Thanks Meter: 22 | with such a attitude i hardly believe u trying to help ... its no problem , u can close or delete post , im gonna find solution myself have a nice day tho |
02-01-2017, 13:03 | #7 (permalink) | |
1. Do you have bootloader unlocked? If yes, process to step 2. 2. Did you install the recovery as described here: http://forum.gsmhosting.com/vbb/f961...tions-2170866/ ? | |
02-01-2017, 17:56 | #8 (permalink) |
Member: 2622097 Status: Offline Thanks Meter: 22 | appreciate for answer , well i did unlock bootloader , i also flashed recovery but when i try to do S-OFF i get this msg : Please wait, preparing your phone... Sorry, error: more than one device and emulator is not yet supported. ( this msg i get when phone is fully powered on ) and in recovery mode phone is not recognized by program : Phone DISconnected |
02-01-2017, 18:37 | #9 (permalink) | |
02-01-2017, 20:46 | #10 (permalink) |
Member: 2622097 Status: Offline Thanks Meter: 22 | i manage to repair imei now , reinstaled drivers and used motherboard ports , thanks for ur help and time |
The Following User Says Thank You to bah300 For This Useful Post: |
08-23-2018, 11:58 | #12 (permalink) |
Junior Member Join Date: Aug 2018 Location: delhi
Member: 2859417 Status: Offline Sonork: [email protected] Thanks Meter: 3 | Please contact me on Skype - xtc2clip, I will check via teamviewer, probably the problem is in drivers. |
