GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   xtc2cliP (https://forum.gsmhosting.com/vbb/f961/)
-   -   Error: Cannot obtain server address. Please try again later. (https://forum.gsmhosting.com/vbb/f961/error-cannot-obtain-server-address-please-try-again-later-2075796/)
osom1234 04-08-2016 20:54
Starting bootloader unlock procedure
Phone detected, reading token...
Token detected successfully
Checking server connection...
rogeliomalpa 04-10-2016 03:46
I thought I was the only one, i'm trying to unlock a phone and all i can see is that message:(
XTC 2 Clip team, is this a temporary trouble?
rogeliomalpa 04-10-2016 04:59
Update
Edit:
I dont know if XTC have fixed the error in the server or it was my pc.
The only thing I do was unnistalling 1.18 and trying to update to 1.19
While the 1.19 installation was finishing i get a error and couldnt open it.
I fixed it by deleting all the XTC 2 Clip files from C://Program Files/ and cleaning my pc with CCleaner. I don't know what was the solution but it is working now.
Thanks again to XTC team for this unbelievable software lml
xtc2clip 04-10-2016 18:34
Hello,
Thanks for the detailed report of your problem and solution.
We can confirm that we had no down-time of our servers, so it must be something on your side.
Feel free to contact us anytime in case of any troubles.
Thanks!!!
marple 04-13-2016 14:04
Disable antivirus program he making problem just like in my case,or disable him till next restart-specialy if you using Avast
xtc2clip 04-13-2016 14:30
Better add only XTC 2 Tool to the exception list, as totally disabling the antivirus may leave your PC unprotected.
tomas.a.sanchez 03-19-2017 07:07
Unable to unlock
Iam trying to unlock an E8 Mec_WHL and have check all also have got of firewall as same as avast.
This is the log:
Trying to connect in Sprint mode...
Trying to connect on COM8
Error: Cannot obtain server address. Please try again later - please check your firewall settings also.
Trying to connect on COM9
xtc2clip 03-19-2017 13:35
This is the log:
Hello,
Please make sure you can access XTC2.net in your browser.
tomas.a.sanchez 03-21-2017 08:11
Originally Posted by xtc2clip (Post 12404407)
Hello,
Please make sure you can access XTC2net in your browser.
Well at the end what I did was that I root the phone and put the TWRP, then flash a firmware based on kit kat, then it downgrade and I was able to do with a tutorial found on other forum flashin an HTcommand file ... all unlocked and then unlock bands with dial code. I was unable to do it with the clip...
mobile_sujan01 04-09-2017 09:17
yeah 100% anti virus problem
kachman 07-29-2017 13:39
i am also having this problem, the PC is newly formatted with no antivirus installed and Firewall turned off. am also able to access xtc2clip.net.
What could be the problem?
helpo 03-07-2019 13:48
I use vpn
but i tired to use free 500 mb vpn then ask for upgrade
for team plz need solution
xtc2clip 03-07-2019 13:53
Hello,
Anyone with this problem please make sure you can access http://xtc2.net (this is our only original site) in your browser.
helpo 03-08-2019 22:03
Originally Posted by xtc2clip (Post 13572368)
Hello,
This can access to
But support only via vpn
Sent from my INE-LX1 using Tapatalk
sjames11501 03-09-2019 18:50
Im having this problem to. I think he problem is on your end. please help
Page generated in 0.19003 seconds with 6 queries
