01-18-2018, 17:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | error flashing M8_UL Starting flash process... target rom version: 6.12.401.4 found large-zip header, file count: 6 processing file 1/6... sending 'zip' (53965 KB)... OKAY [ 3.143s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... FAILED (remote: 22 loading zip info fail Please check if you flash par) finished. total time: 3.430s Flash process completed. Flash not successfull, reboot will not be done here is phone info: Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.29.214500021.11G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 6.13.661.9 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: SH4AXWM02393 (bootloader) imei: 357336065047596 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B10000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (Hboot PreUpdate) (bootloader) commitno-bootloader: 205bdca3 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 26(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 20(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 19(ms) Reading IMEI1 information ... (bootloader) imei: 357336065047596 OKAY Execution time is 22(ms) Reading IMEI2 information ... (bootloader) readimei2: Not Support OKAY Execution time is 21(ms) Reading secure flag information ... (bootloader) secure_flag: 0 OKAY Execution time is 20(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 20(ms) Read information completed. thnak you! Last edited by equinoks; 01-18-2018 at 17:41. |
01-18-2018, 18:57 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello. Check if bootloader is unlocked, if it is - try to lock it (oem lock). Otherwise, try to flash via SD - rename file to 0P6BIMG.zip and put on SD card (NOT on the clip). |
