03-07-2018, 23:00 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: lima peru
Member: 787364 Status: Offline Sonork: 100.1617985 Thanks Meter: 9 | error repair u11 [SOLVED] I leave logos of the operation images I hope help Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_ocnwhl (bootloader) version: 1.0 (bootloader) max-download-size: 1562400000 (bootloader) serialno: FA77L0501122 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 358182080421385 (bootloader) version-main: 1.28.598.4 (bootloader) boot-mode: download (bootloader) version-baseband: 8998-001791-1706061715 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PZC50000 (bootloader) cid: HTC__332 all: Execution time is 6(ms) Reading CID information ... (bootloader) cid: HTC__332 OKAY Execution time is 6(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 5(ms) Reading IMEI1 information ... (bootloader) imei: 358182080421385 OKAY Execution time is 5(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 5(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 4(ms) Reading serial number information ... (bootloader) Device Serial No. is FA77L0501122 OKAY Execution time is 6(ms) Read information completed. 1. Checking phone connectivity... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem reboot-download ... OKAY Execution time is 3(ms) Waiting for the phone to reboot... Phone DISconnected Phone connected [FA77L0501122] *** Fastboot mode Phone connected Sending oem readimei ... (bootloader) imei: 358182080421385 OKAY Execution time is 6(ms) Operation completed! Releasing adapter. Request completed 1. Checking phone connectivity... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writeimei 353777778788782 ... (bootloader) [ERR] Command error !!! OKAY Execution time is 15(ms) Operation completed! Releasing adapter. Request completed |
03-08-2018, 10:12 | #6 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | u11 s-off not supported problem is here please check Quote:
03-08-2018, 14:44 | #7 (permalink) |
Member: 787364 Status: Offline Sonork: 100.1617985 Thanks Meter: 9 | yes bro repair true!! thank you lords , repair htc u11, greetings from peru |
The Following 2 Users Say Thank You to fresco353 For This Useful Post: |
04-20-2018, 07:33 | #9 (permalink) | |
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
11-09-2018, 05:54 | #10 (permalink) |
Junior Member Join Date: May 2014
Member: 2192385 Status: Offline Thanks Meter: 1 | Goodnight I already managed to load the new recovery but only letters come out and it stays stuck I need to repair the imei I read that I had to be off and I did not achieve it either someone with the solution please |
11-09-2018, 15:55 | #11 (permalink) | |
