09-29-2015, 01:39 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Redlands Ca Age: 49
Member: 810122 Status: Offline Thanks Meter: 65 | Fastboot M9 not working Always no response with fastboot |
09-29-2015, 09:09 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: YODAFON
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | Connect phone in fastboot mode, than manually change driver from "adb interface" the google driver to the htc driver. It should apperar as "my htc". |
09-29-2015, 09:15 | #5 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Unfortunately you are not correct. There IS a download mode on all modern phones, and furthermore bootloader mode is depricated and used to boot phone only. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
09-29-2015, 09:15 | #6 (permalink) | |
http://xtc2.net/downloads/HTCDriver.msi | |
09-29-2015, 09:16 | #7 (permalink) | |
Member: 810122 Status: Offline Thanks Meter: 65 | Quote:
Im confused ok im supposed to use download mode on M9 in htc fastboot mode right Download is fastboot and switch google driver to HTC driver right ?? If yes i will try that Had to waste money on sunshine becasuse i did not want to lose the sale..... SIGH!!! | |
09-29-2015, 09:19 | #8 (permalink) |
Major Poster Join Date: Dec 2005 Location: Poland
Member: 209265 Status: Offline Thanks Meter: 1 | M9's are a bit different than the other HTC's. I have recently had similar problem. There is no HBOOT but ABOOT in this phone. All fastboot commands should work properly in download mode. Switch the phone off. Press and hold Volume down button; while doing so press once Power key in order to power on your device – don’t release the Volume Down key though. Phone should boot into Download Mode. Or you can reboot to D mode using ADB command: adb reboot download. |
09-29-2015, 09:24 | #10 (permalink) | |
thank you and i should switch the driver to htc from google right ? | |
09-29-2015, 10:24 | #12 (permalink) | |
09-29-2015, 12:11 | #13 (permalink) |
Member: 75392 Status: Offline Sonork: 100.81199 Thanks Meter: 136 | thanx, I didn't knew that, I never had a M9 for servicing till now. But before M9 "adb reboot download" just rebooted the phone because there was no download mode to boot too, I had to use adb reboot bootloader... but thanx , good to know... |
