08-31-2017, 18:58 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | flash phone FAILED (remote: 9: SD_SECURITY_FAIL zip from usb command in download mode Starting flash process... found large-zip header, file count: 8 processing file 1/8... sending 'zip' (63444 KB)... OKAY [ 4.874s] writing 'zip'... (bootloader) HOSD CL#511781 FAILED (remote: 9: SD_SECURITY_FAIL zip from usb command in download mode) finished. total time: 5.884s Flash process completed. Flash not successfull, reboot will not be done |
The Following User Says Thank You to chipscell25 For This Useful Post: |
01-18-2018, 05:19 | #3 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2800997 Status: Offline Thanks Meter: 0 | Y KLK. oye mi loko TU LO QUE NECESITAS ES DESBLOQUEAR DE NUEVO EL BOOTLOADER HASLO TRANKILAMENTE DESDE LA PAGINA OFFICIAL DE HTC https:// www . htcdev . com / devcenter / downloads YA TU SABE NO VEMO AHORITA. |
10-15-2020, 16:57 | #4 (permalink) | |
Junior Member Join Date: Feb 2011 Location: Türkiye
Member: 1514914 Status: Offline Thanks Meter: 1 | s off problem htc d728n Quote:
1. Checking phone connectivity...... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage.. Phone connection confirmed! Requested card version not detected, version 6 will be used 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writecid 11111111 ... FAILWRITE CID PERMISSION ERROR FAILED (remote: WRITE CID PERMISSION ERROR) finished. total time: 0.008s htc_fastboot finished Operation completed! Releasing adapter. Request completed | |
