02-02-2019, 08:40 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 644581 Status: Offline Thanks Meter: 16 | Flash Problem U11 So ... device:u11 was with US firmware ( i wanted EU ) so i did like this: Unlocked BL - OK Downgrad so i can SuperCID - OK superCID - OK Changed Model - OK Now i have a problem. I cant flash nothing except custom ROM Allways error 14 Any Help ? Thank you in advance PS Log here Starting flash process... target rom version: 1.13.401.1 found large-zip header, file count: 26 processing file 1/26... sending 'zip' (109944 KB)... OKAY [ 4.229s] writing 'zip'... (bootloader) HOSD CL#954392 (bootloader) GPT (gpt_main_64g_sda.img) is up-to-dated. [24576] (bootloader) GPT (gpt_main_64g_sdb.img) is up-to-dated. [24576] (bootloader) GPT (gpt_main_64g_sdc.img) is up-to-dated. [24576] (bootloader) GPT (gpt_main_64g_sdd.img) is up-to-dated. [24576] (bootloader) GPT (gpt_main_64g_sde.img) is up-to-dated. [24576] (bootloader) GPT (gpt_main_64g_sdf.img) is up-to-dated. [24576] (bootloader) Perform pre-update (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 24 images from zip(zip_type=3) (bootloader) ERR ZIP signature checking failed... (bootloader) ERR [SD_UPDATE_ERR] Not allow flash image except boot/recov (bootloader) ery/system (bootloader) ERR [SD_UPDATE_ERR] update_fb_ZIP_buf: fail to flash zip: 1 (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 14 (bootloader) ERR Update zip file failed. (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 14 (bootloader) end@Done FAILED (remote: 14 RU_ZIP_INFO_ERROR android-info missing or malformed ) finished. total time: 8.963s HBoot pre-update sequence Last edited by spinky360; 02-02-2019 at 08:50. |
02-03-2019, 15:39 | #5 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Have you used these flash files with another U11 previously? Just to make sure file is not corrupted. You can also check it with MD5 hasher and compare hash to the one from our web-site. | |
