Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 12-24-2016, 21:52   #16 (permalink)
romell's Avatar
Member: 252707
Thanks Meter: 18
Not work this file...
Enviado desde mi SM-G935F mediante Tapatalk
Old 12-24-2016, 23:08   #17 (permalink)
Member: 2606705
Good afternoon somebody can help me when trying to install twrp-3.0.2-0-a16 in my desire 530 chile, it installs to 100% when restarting in recovery mode it throws me the following message:
Failed to boot recovery mode press volume up or down to back menu
Model id: 2PST23000
Product id: HTC a16ul.
Someone who can help, thank you very much.
Old 12-25-2016, 00:57   #18 (permalink)
Member: 2487890
Thanks Meter: 72
TRY this recovery file.
Zippyshare.com - a16_ul_recovery_modified.img
I rebuild it from stock recovery and enable ADB function as root.
The Following User Says Thank You to sabpprook For This Useful Post:
Old 12-25-2016, 14:33   #19 (permalink)
Member: 155397
Thanks Meter: 21
530 S-OFF on ok ok ok ok ok ok
24/12/2016 18:50:43 Operation finished
24/12/2016 18:50:47 Please wait, preparing your phone...
24/12/2016 18:50:48 HTC Desire 530 detected
24/12/2016 18:50:48 Android release: 6.0.1
24/12/2016 18:50:49 Checking server connection...
24/12/2016 18:50:49 Communicating with the XTC 2 Clip ...
24/12/2016 18:50:55 Connecting to the server...
24/12/2016 18:50:55 Please wait, processing your request...
24/12/2016 18:51:04 Finished. Your phone will be S-OFF on restart.
24/12/2016 18:51:05 Phone DISconnected
24/12/2016 18:51:54 Phone connected [FA63JBR01664] *** ADB mode
24/12/2016 18:53:17 Sending reboot-bootloader
The Following 2 Users Say Thank You to ayhan02 For This Useful Post:
Old 12-27-2016, 01:53   #20 (permalink)
Member: 721542
Thanks Meter: 56
BL unlocked.
Starting bootloader unlock procedure
Phone detected, reading token...
Token detected successfully
Waiting for the server to process request, it may take up to 5 minutes...
Your request was processed successfully! Unlock token has been obtained
Sending flash unlocktoken "C:\Program Files (x86)\XTC 2 Tool\\unlocktoken_HT68SBR04283.bin"
sending 'unlocktoken' (0 KB)... OKAY
writing 'unlocktoken'... (bootloader) flash unlocktoken
(bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp
(bootloader) [KillSwitch] Last Byte is 0X01, enable unlock
(bootloader) unlock token check successfully
OKAY
Execution time is 2(s)
Please continue the unlock process on your phone.
Phone DISconnected
Phone connected [HT68SBR04283] *** Fastboot mode
Phone DISconnected
recovery flashed.
Starting flash process...
target reported max download size of 725000000 bytes
sending 'recovery' (24124 KB)...
OKAY [ 2.996s]
writing 'recovery'...
(bootloader) HOSD CL#736479
(bootloader) start@1
(bootloader) recovery@100%
(bootloader) Update partition OK
(bootloader) end@Done
OKAY [ 2.757s]
finished. total time: 5.753s
Recovery flash process completed.
when i boot the phone into recovery, it stayed in that mode and software wont recognise. how can i soff it?
Old 12-27-2016, 01:53   #21 (permalink)
Member: 721542
Thanks Meter: 56
how did you get this one done? and after you chose recovery, phone stays there or boot in normal?
Old 12-27-2016, 02:12   #22 (permalink)
Member: 721542
Thanks Meter: 56
got it
Phone DISconnected
Old 12-29-2016, 23:20   #23 (permalink)
Member: 607283
Thanks Meter: 10
help
What am i doing wrong? software say this after whrite recovery you left here
Sorry, - exec '/system/bin/sh' failed: No such file or directory (2) -
is not yet supported.
Old 12-30-2016, 20:37   #24 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
S-OFF + simlock HTC Desire 530 from T-Mobile success! CID was WFM__001, MID 2PST20000.
Make please conversion to European MID 2PST10000 for flashing European zip 1.22.401.1 without T-Mobile garbage.
Old 12-31-2016, 04:03   #25 (permalink)
Member: 1314806
Sonork: 100.1000
Thanks Meter: 80
I have a question. I have a HTC 10 from Verizon. can I change only cid. for unbranded? or I need unlock bootloader?
Old 01-04-2017, 00:28   #26 (permalink)
Member: 220595
Thanks Meter: 355
is the metropcs version unlockable ?
got one here and it is just ignoring the clip, after trying to boot in FTM mode, it just reboots and boot android, thus ignoring clip
there is no log file in the clip to show here.
for unlocking is it mandatory to s-off first ?
does the twrp image floating here works on this version? a16ul
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_a16ul
(bootloader) version: 1.0
(bootloader) imei: 358869072705136
(bootloader) version-main: 1.01.1550.25
(bootloader) boot-mode: download
(bootloader) version-baseband: 01.01_U113251211_63.10.60527G
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PST20000
(bootloader) cid: METRO001
all:
Execution time is 61(ms)
Reading secure flag information
... (bootloader) Device security level S-ON
OKAY
Execution time is 28(ms)
Reading CID information
... (bootloader) cid: METRO001
OKAY
Execution time is 51(ms)
Reading MEID information
... (bootloader) meid:
OKAY
Execution time is 48(ms)
Read information completed.
Old 01-04-2017, 10:29   #27 (permalink)
Crazy Poster
Member: 1954652
Thanks Meter: 11
ayhan o2 nasıl yaptın işlem sıralaması nedir anlatırmısın
Old 01-04-2017, 12:14   #28 (permalink)
VIBINDAS_INDIA's Avatar
Member: 707582
Sonork: 100.1620432
Thanks Meter: 334
htc 530u S-OFF failed with 1.29
see this log
Sorry, adb server is out of date. killing...
* daemon started successfully *
htc_a16
NB: bootloader UNLOCKED , RECOVERY write compleate and BOOT MODE changed to RECOVERY MODE , device in TWRP recover stage
Old 01-04-2017, 17:51   #29 (permalink)
Member: 2449091
Twrp is not compatible with htc 530 claro chile
None of the two left in the post
Old 01-04-2017, 19:59   #30 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
Originally Posted by VIBINDAS_INDIA View Post
see this log
htc_a16
Kill external adb server and repeat operation.
Be sure that HTC_A16 supported. Here log of S-OFF from TWRP:
30.12.2016 21:16:09 Phone connected [HT66LBR00217] *** ADB mode
30.12.2016 21:16:14 Please wait, preparing your phone...
30.12.2016 21:16:14 HTC Desire 530 detected
30.12.2016 21:16:15 Android release: 6.0.1
30.12.2016 21:16:16 Checking server connection...
30.12.2016 21:16:16 Communicating with the XTC 2 Clip ...
30.12.2016 21:16:27 Connecting to the server...
30.12.2016 21:16:28 Please wait, processing your request...
30.12.2016 21:16:38 Finished. Your phone will be S-OFF on restart.
30.12.2016 21:16:38 Phone DISconnected
Fastboot info before S-OFF:
30.12.2016 20:29:53 Phone connected [HT66LBR00217] *** Fastboot mode
30.12.2016 20:29:56 Reading information...
30.12.2016 20:29:56 Using Fastboot mode...
30.12.2016 20:29:56 Reading common information
30.12.2016 20:29:56 (bootloader) kernel: lk
(bootloader) imei: 35941707xxxxxxx
(bootloader) version-main: 1.01.352.25
(bootloader) boot-mode: RUU
(bootloader) cid: WFM__001
all:
Execution time is 21(ms)
Page generated in 0.25260 seconds with 9 queries
