01-11-2017, 10:48 | #47 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
The Following User Says Thank You to xtc2clip For This Useful Post: |
01-11-2017, 16:30 | #49 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
So, now what? how do I unlock the phone? I will try to s-off now. | |
01-11-2017, 18:37 | #52 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hello After bootloader unlock, I have tried to unlock using the usual SD method with the desire 530 files copied to the clip This time the phone is not ignoring the clip but am getting the error on the image Enviado desde mi SM-N920T mediante Tapatalk |
01-11-2017, 19:35 | #53 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Finally worked out to unlock the beast... desire 530 metropcs Finally I managed to unlock the phone. there is lack of support here !!! one has to find the answers oalmost on their own... To unlock phone you * MUST * 1. enable OEM Unlock on developer options 2. Unlock BootLoader 3. s-OFF 4. Copy the required desire 530 files using SD Editor TAB 5. Insert Clip as SD in phone and use FTM Button only after all of this phone will be unlocked, there is no other way for now !! Bootloader unlock process (only works after :Enable Oem Unlock) Code: Starting bootloader unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Waiting for the server to process request, it may take up to 5 minutes... Your request was processed successfully! Unlock token has been obtained Sending flash unlocktoken "C:\Program Files (x86)\XTC 2 Tool\\unlocktoken_FA6AXBR01351.bin" sending 'unlocktoken' (0 KB)... OKAY writing 'unlocktoken'... (bootloader) flash unlocktoken (bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp (bootloader) [KillSwitch] Last Byte is 0X01, enable unlock (bootloader) unlock token check successfully OKAY Execution time is 1(s) Please continue the unlock process on your phone. Code: Please wait, preparing your phone... HTC Desire 530 detected Android release: 6.0.1 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, processing your request... Finished. Your phone will be S-OFF on restart. Phone DISconnected |
01-12-2017, 03:10 | #59 (permalink) |
Crazy Poster Join Date: Oct 2014
Member: 2280189 Status: Offline Thanks Meter: 10 | special unlock/IMEI Tab right because in the sd mode editor Tap only shows that i have to put the imei and secury s-off and more i dont know what im doing wrong.. thank for you advise |
The Following User Says Thank You to Leo_systems For This Useful Post: |
01-12-2017, 03:23 | #60 (permalink) | |
Enviado desde mi SM-N920T mediante Tapatalk | |
