03-13-2017, 01:17 | #92 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
What I can read there is a way to recover from brick or restore, using a tmobile RUU after extracting system and boot images... can you share where to find information regarding convertion to european ? | |
03-13-2017, 03:06 | #94 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | insert the xtc clip in the phone sd slot and try enter recovery, after entering recovery mode with xtc inserted in phone, you will see option to hard reset. |
03-13-2017, 03:44 | #95 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: infinity
Member: 817412 Status: Offline Sonork: 1618066 Thanks Meter: 69 | Error Quote:
BRO TWRP Starting flash process... target reported max download size of 725000000 bytes sending 'recovery' (10690 KB)... OKAY [ 1.611s] writing 'recovery'... (bootloader) HOSD CL#761159 FAILED (remote: 9 RU_SECURITY_FAIL recovery and bootloader isn't BL_UNLOCKE) finished. total time: 2.623s Flashing cannot be done in this mode, please reboot to RUU mode (use RUU button) and repeat flashing! Recovery flash process completed. FLASHING Starting flash process... target rom version: 1.01.620.1 found large-zip header, file count: 18 processing file 1/18... sending 'zip' (156996 KB)... OKAY [ 10.065s] writing 'zip'... (bootloader) HOSD CL#761159 FAILED (remote: 9 RU_SECURITY_FAIL zip from usb command in download mode) finished. total time: 11.076s Flashing cannot be done in this mode, please reboot to RUU mode (use RUU button) and repeat flashing! Flash process completed. Flash not successfull, reboot will not be done | |
03-13-2017, 07:13 | #96 (permalink) |
Member: 817412 Status: Offline Sonork: 1618066 Thanks Meter: 69 | solution 100% Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_a16ul (bootloader) version: 1.0 (bootloader) imei: 355520022920000 (bootloader) version-main: 1.01.620.1 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U113251341_58.01.60510G (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PST23000 (bootloader) cid: 11111111 all: Execution time is 21(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 69(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 8(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 9(ms) Read information completed. Phone DISconnected |
03-13-2017, 21:48 | #98 (permalink) | |
Insane Poster Join Date: Apr 2011 Location: Romania
Member: 1555576 Status: Offline Thanks Meter: 11 | Quote:
me too i have this problem. | |
03-13-2017, 22:26 | #99 (permalink) |
Member: 1555576 Status: Offline Thanks Meter: 11 | I reflash sd clip with image2015.img file, I copy files again on special unlock/IMEI and here is the log: Code: =============================== XTC 2 Clip - service tool v2.14 Detected release: A16_UL_M60_DESIRE_SENSE70GP Detected model: Desire 530 [QCT] Preparing for work... Clip ID: xxxxxxxx Error: Please upgrade your clip (B3) Note: Use XTC 2 Client for upgrade! Rebooting in 5 seconds ... Rebooting in 4 seconds ... Rebooting in 3 seconds ... Rebooting in 2 seconds ... Rebooting in 1 seconds ... |
03-14-2017, 11:15 | #100 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | Starting flash process... target reported max download size of 714000000 bytes sending 'recovery' (24124 KB)... OKAY [ 3.138s] writing 'recovery'... (bootloader) HOSD CL#769277 FAILED (remote: 9 RU_SECURITY_FAIL recovery and bootloader isn't BL_UNLOCKE) finished. total time: 4.150s Flashing cannot be done in this mode, please reboot to RUU mode (use RUU button) and repeat flashing! Recovery flash process completed. |
03-14-2017, 12:54 | #101 (permalink) |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | Unlock Desire 530 2PST20000 cid: WFM__001 is Done 1. unlock bootloader 2. Go to S-OFF & flash " twrp-3.0.2-0-a16 " 3. Go to special unlock/imei select HTC Desire 530(A16)(UNLOCK) Bootloader service option, select "Do nothing" press Copy files. 4.Connect XTC2clip to phone Reboot to bootloader (Use "Bootloader" button in XTC 2 Tool or use download mode menu), and then choose "Reboot to recovery". you will see recovery mode on screen with TWRP you flashed at step 2 like https://www.howtogeek.com/wp-content...RP-restore.png. 5. Go to S-OFF, "S-OFF & Bootloader unlocked" Do s-off Connect XTC2clip to PC 6. Go to SD mode editor click on upper imei to load youre imei on "lock/unlock imei list(for lock/unlock omly)" (a)SELECT New CID (b)SELECT Lock press SAVE TO DRIVE 7. Connect XTC2clip to phone with phone connected to usb press FTM Wait oparation to finish. Unlock Desire 530 2PST20000 cid: WFM__001 is Done My phone looks like this with CID not changed but unlocked, remember this t-mobile have unlock APP !! Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_a16ul (bootloader) version: 1.0 (bootloader) imei: 359xxx070283xx5 (bootloader) version-main: 1.01.352.23 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U113251211_63.10.60527G (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PST20000 (bootloader) cid: WFM__001 all: Execution time is 38(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 76(ms) Reading CID information ... (bootloader) cid: WFM__001 OKAY Execution time is 12(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 13(ms) Read information completed. Phone DISconnected Last edited by kawalya; 03-14-2017 at 13:03. |
03-14-2017, 13:20 | #102 (permalink) |
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | Is look that whe are 3 user what have same error (bootloader) HOSD CL#769277 FAILED (remote: 9 RU_SECURITY_FAIL recovery and bootloader isn't BL_UNLOCKE) i use all type of mode possible to write |
03-16-2017, 11:59 | #103 (permalink) |
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | 1st: SORRY 2ND: to write any custom ruu htc need bootloader unlock reason way nobody answer to my quastion. SOO TO UNLOCK 530 NEED UNLOCK BOOTLOADER FIRST VIA DEVTEAM OR XTC. SECOND TWRP INSTAL VIA CMD OR XTC. 3RD DO SOFF Please wait, preparing your phone... HTC Desire 530 detected Android release: 6.0.1 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, processing your request... Finished. Your phone will be S-OFF on restart. Phone DISconnected AFTER IS SOFF GO TO SD MODE EDITOR DO THAT STEP INSERT XTC SD FLEX IN SET REBOOT SET TO FTM AND THATS ALL. |
03-18-2017, 20:35 | #104 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1651353 Status: Offline Thanks Meter: 92 | Here the solution https://www.************/forum/index....0#entry1763934 |
03-19-2017, 16:22 | #105 (permalink) |
Freak Poster Join Date: Nov 2008 Location: desde colombia
Member: 897743 Status: Offline Sonork: 100.1604114 Thanks Meter: 66 | please help my friends error is S-OFF HTC M10, Android 7.1.1 [IMG][/IMG] br Nannocell12 Last edited by nanocell; 03-19-2017 at 16:29. |
