Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 07-27-2015, 20:34   #1 (permalink)
Member: 2416253
Thanks Meter: 4,162
GUIDE: Desire X/SV/C/V/U/200/300/500/600/One V/etc IMEI repair
Desire X/SV/C/V/U/200/300/500/600/One V/etc IMEI repair manual
Dear customers,
If your phone has no "writeimei" command in fastboot mode, here are the steps to repair IMEI (IMEI2):
- If your phone is not S-OFF, please make it S-OFF using the desired method (direct or SD (offline) mode)
- Connect your phone in fastboot mode
- Go to "Legacy" tab and press "Step 2. Switch to modem mode". WARNING! You must issue this command as a first command after phone was powered on!
If you will use any other command prior to switching to modem mode (e.g. read phone info, etc, it will fail in most cases)
- Wait for the phone to switch into modem mode (you may use the manual from here as well: http://forum.gsmhosting.com/vbb/f961...ngdom-1967505/)
- Perform IMEI or IMEI 2 repair
Please note you must use XYC 2 Clip Tool 1.06 or higher for this.
Thank you.
The Following 13 Users Say Thank You to xtc2clip For This Useful Post:
Old 09-14-2015, 09:06   #2 (permalink)
Member: 69712
Thanks Meter: 8
Desire 500 single sim version without writeimei command in fastboot:
Sending oem writeimei 3580440xxxxxxxx
... (bootloader) [ERR] Command error !!!
Execution time is 17(ms)
OKAY
Operation finished
Does not work in offline(sdcard) mode also.
S-OFF successful, bootloader unlock- also. I even downgraded hboot(was 1.03.001 up to 1.01.001) but still no success.
The question is: do I have to put the SIM card of the clip to SIM try of the phone as described in legacy tab?! As Desire 500 is with micro sim slot and I'm a bit afraid to cut the clip SIM...when I try without SIM I'm able to activate modem port, soft can see it and connect to it successful but don't read/write any info in this mode...
Old 09-14-2015, 16:25   #3 (permalink)
rico1's Avatar
Member: 5397
Thanks Meter: 38
i also have this problem
"Sending oem writeimei 3580440xxxxxxx
Execution time is 42(ms)
OKAY
Operation finished
how to solved?
Old 09-28-2015, 22:22   #4 (permalink)
Member: 1510211
Thanks Meter: 25
Htc Z10e Sensation is posible unlock?
Old 09-29-2015, 09:09   #5 (permalink)
Member: 2416253
Thanks Meter: 4,162
Please post complete information from XTC2Tool after reading info in fastboot mode.
Old 10-01-2015, 02:47   #6 (permalink)
Member: 1510211
Thanks Meter: 25
the client took the phone, if he returns to bring upload the information, thanks.
Old 10-03-2015, 08:45   #7 (permalink)
Member: 165586
Thanks Meter: 17
desire 500 install driver in modem mode. but xtc2tool dont show com ports. Cant choose anything
Old 10-03-2015, 12:07   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
Run software as administrator please. (Run click on exe -> Run as administrator)
Old 10-20-2015, 18:16   #9 (permalink)
Member: 33166
Thanks Meter: 4
Desire 500 repair imei
I can't find answer- need cut xtc2clip smartcard to micro or not? Smartcard must be inserted into phone sim slot, when in legacy tab try switch phone in modem mode?
Old 10-20-2015, 18:30   #10 (permalink)
Member: 2416253
Thanks Meter: 4,162
The answer is NO.
There is no legacy phones with microSIM.
Old 10-20-2015, 19:30   #11 (permalink)
Member: 33166
Thanks Meter: 4
Thank's for answer. Then please help repair imei on my my HTC desire 500 (dual sim) Z4DUG. I made security off, super cid via SD mode, but imei not repaired via SD mode. Can't repair imei via direct mode too. Direct mode:
Sending oem writeimei 35454505xxxxxxx
OKAY
Operation finished
Thank you in adnvance
Old 10-20-2015, 19:37   #12 (permalink)
Member: 33166
Thanks Meter: 4
In SD mode looks like all ok, but really imei not repaired
Old 10-22-2015, 07:28   #13 (permalink)
Member: 1886680
plz hel for this method
Old 10-22-2015, 17:43   #14 (permalink)
Member: 2416253
Thanks Meter: 4,162
Guys, I don't understand, do you read at all?
Have you read the FIRST topic of this thread? Your posts are just a spam, that will confuse other customers.
It's clearly said - use LEGACY mode. But instead of this, you try to use SD and Direct modes, and post useless screenshots and error descriptions. Why?
Old 10-22-2015, 17:44   #15 (permalink)
Member: 2416253
Thanks Meter: 4,162
Topic closed, I don't want other customers to be confused.
The Following User Says Thank You to xtc2clip For This Useful Post:
Page generated in 0.27334 seconds with 10 queries
