Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 07-09-2015, 10:19   #1 (permalink)
Member: 2416253
Thanks Meter: 4,162
GUIDE: Legacy phones (ace,buzz,vision,icon,legend,saga,bliss,chacha,run nym.,kingdom)
Dear customers,
With the release of XTC2Clip Tool version 1.04 you have an option for convenient service of "legacy" phones, which includes:
- Desire HD [ace]
- Wildfire [buzz]
- Desize Z (G2/A7272) [vision]
- Salsa [icon_g]
- Legend A6363 [legend]
- Desire S [saga]
- Rhyme [bliss]
- ChaCha [chacha]
- Sensation XL [runnymede]
- EVO Design 4G [kingdom]
... and other legacy HTC phones.
In order to perform the desired action, you have to follow this instructions:
As on all HTC phones, there are 2 operation modes:
* Offline mode: CID, lock, unlock
* Direct mode: S-OFF, CID, IMEI, unlock
1. No matter what mode are you going to use, you must carefully EJECT the smartcard from the XTC2Clip and put it into your phone as a SIM CARD.
2. Offline mode:
- Put necessary files (CID and/or unlock config.dat) on the CLIP and connect it to your phone
- Go to fastboot->Simlock and perform operation as usual.
2. Direct mode:
- Connect phone in fastboot mode
- Go to legacy tab in XTC 2 Clip Tool
- Press "Step 2: Switch to modem mode", this will switch your phone into special modem mode.
- Install drivers, if necessary. ( Get drivers HERE: http://xtc2.net/downloads/qhsusb.rar )
- Press "Refresh" and select appropriate COM port (there usually will be only one).
- Press "Step 3: Connect"
- The software will read information from the phone, and you can continue to perform the desired operations.
The Following 12 Users Say Thank You to xtc2clip For This Useful Post:
Old 07-09-2015, 11:26   #2 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
Thanks for great update ... please add official flash file support site and flashing tab in xtc2clip
Regards
Old 07-14-2015, 04:21   #3 (permalink)
Member: 2427789
Sonork: 100.1667958
Help!!
Regards
help .. the "htc wildfire s" is supported ??
Old 07-14-2015, 10:56   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
Yes, it should be supported, as Wildfire is supported.
Old 07-15-2015, 06:38   #5 (permalink)
Member: 2427789
Sonork: 100.1667958
in this mode detects legacy me 3 COM ports.
Old 07-15-2015, 10:57   #6 (permalink)
Member: 2416253
Thanks Meter: 4,162
Yes, that's fine. 2 will be under COM ports and 1 for modem. You need the modem one.
Old 07-28-2015, 14:53   #7 (permalink)
Member: 955311
Thanks Meter: 241
HOW TO PUT IN modem mode?
Old 07-28-2015, 15:02   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
I think nobody in the world knows the answer, the only way to touch the truth is to read message #1 from this post, but psh... don't tell anyone
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 07-29-2015, 12:25   #9 (permalink)
fonefun's Avatar
Member: 26187
Sonork: 100:77458
Thanks Meter: 290
i have a htc desire
a buzz phone, part of legacy family
we have tried direct mode but when we press "step 2 switch to modem mode" the phone doesnt react or change)
we also have deice manager open and see no change
any tips for this?
Old 07-29-2015, 13:53   #10 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by fonefun View Post
i have a htc desire
any tips for this?
Try to issue this command as a first command after the phone is connected.
Old 07-29-2015, 17:59   #11 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 245
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.01.0001
(bootloader) version-baseband: 3.35.20.10
(bootloader) version-cpld: None
(bootloader) version-microp: 0622
(bootloader) version-main: 2.22.405.4
(bootloader) serialno: SH14CPY00274
(bootloader) imei: 357758045462043
(bootloader) product: buzz
(bootloader) platform: HBOOT-7225
(bootloader) modelid: PC4910000
(bootloader) cidnum: HTC__001
(bootloader) battery-status: good
(bootloader) battery-voltage: 4161mV
(bootloader) partition-layout: HTC
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-72b8c698
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
Execution time is 0(ms)
all: Done!
Reading secure flag information
... (bootloader) [ERR] Command error !!!
Execution time is 15(ms)
OKAY
Reading CID information
OKAY
Read information completed.
can this phone be unlock with direct mode
Old 07-29-2015, 18:01   #12 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 245
Trying to swtich into modem mode ...
Sending oem rtask
c
not going in to modem mode any suggestion
Old 08-08-2015, 15:32   #13 (permalink)
Registered User
Member: 962014
Thanks Meter: 7
hi
i have problem with s-off htc salsa !
i have used sd-editor and smart card method but your tools cant s-off my device
error log in fastboot :
SD init fail !!!
process done reboot device ?
<VOL UP> Yes
and when i used direct mode the xtcclip soft hanged
how to s-off legacy phones?
Old 08-10-2015, 14:15   #14 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by gandolf007 View Post
hi
SD init fail !!!
<VOL UP> Yes
Did you insert the microsd card or xtc2clip in sd mode?
As to direct mode, once switched to modem mode, you must install the drivers and choose the correct com port.
Old 08-11-2015, 22:22   #15 (permalink)
Member: 1423806
Sonork: 100.1685119
Thanks Meter: 44
Originally Posted by sweetboy View Post
c
Same issue here: "Trying to swtich into modem mode ...
Sending oem rtask c"
... nothing happens
BTW its a Wildfire A3333
Page generated in 0.26675 seconds with 9 queries
