Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 01-30-2017, 11:09   #1 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,375
Thumbs up [Guide] M8_UL Semi Bricked, Not "boot up", Repaired Success by Xtc2Clip
Hello, this Htc M8_UL was in Semi Brick and only "Hboot Mode or Fastboot Mode", Success repaired by XTC2CLIP...and little of knowledge about "ROM" and "Flash File".
File Used:
1) Full Rom: 0P6BIMG_M8_UL_M60_SENSE70_MR_HTC_Europe_6.12.401.4 _R_Radio_1.29.214500021.12G_20.72.4196t.01_F_relea se_464423_signed_2_4 Downloaded from Xtc2Clip Support
2) Hboot Updatate: 6.12.401.4+firmware
Let's go to Repair:
First of All Done S-OFF + SuperCid
A) First Flash file at point 2 two time, (mandatory 2 time)
Starting flash process...
target rom version: 6.12.401.4
found large-zip header, file count: 6
processing file 1/6...
sending 'zip' (53965 KB)...
OKAY [  2.426s]
writing 'zip'...
(bootloader) rom parsing start ...
(bootloader) rom parsing finish ...
(bootloader) zip header checking...
(bootloader) zip info parsing...
(bootloader) checking model ID...
(bootloader) checking custom ID...
Processing [hboot], please wait...
(bootloader) total_image_number=8
(bootloader) ...... Successful
(bootloader) current_image_number=0
(bootloader) current_image_number=1
(bootloader) current_image_number=2
(bootloader) current_image_number=3
(bootloader) current_image_number=4
(bootloader) current_image_number=5
(bootloader) current_image_number=6
(bootloader) current_image_number=7
FAILED (remote: 90 hboot pre-update! please flush image again immediately
finished. total time: 6.418s
preupdate done, rebooting...
sending 'zip' (53847 KB)...
OKAY [  2.422s]
writing 'zip'...
(bootloader) shift signature_size for header checking...
(bootloader) total_image_number=13
Processing [adsp], please wait...
Processing [boot], please wait...
Processing [recovery], please wait...
Processing [rpm], please wait...
Processing [sbl1], please wait...
(bootloader) signature checking...
(bootloader) verified fail
(bootloader) ..... Bypassed
Processing [sensor_hub], please wait...
Processing [sp1], please wait...
(bootloader) current_image_number=8
Processing [tz], please wait...
(bootloader) current_image_number=9
Processing [wcnss], please wait...
(bootloader) current_image_number=10
Processing [radio], please wait...
(bootloader) trying to rename MBA
(bootloader) current_image_number=11
Processing [rcdata], please wait...
(bootloader) current_image_number=12
OKAY [ 61.355s]
finished. total time: 63.777s
Flash process completed.
B) Ok Now Can flash "Full ROM" at Point 1
OKAY [  2.431s]
writing 'zip'...
(bootloader) total_image_number=17
Processing [pg2fs_spcustom], please wait...
Processing [tp], please wait...
Processing [sdi], please wait...
(bootloader) current_image_number=13
(bootloader) current_image_number=14
(bootloader) current_image_number=15
(bootloader) current_image_number=16
OKAY [ 61.733s]
finished. total time: 64.164s
processing file 2/6...
sending 'zip' (549729 KB)...
OKAY [ 16.277s]
writing 'zip'...
Processing [system], please wait...
OKAY [ 38.755s]
finished. total time: 55.042s
processing file 3/6...
sending 'zip' (507195 KB)...
OKAY [ 14.992s]
writing 'zip'...
OKAY [ 37.658s]
finished. total time: 52.650s
processing file 4/6...
sending 'zip' (533489 KB)...
OKAY [ 15.631s]
writing 'zip'...
OKAY [ 35.679s]
finished. total time: 51.310s
processing file 5/6...
sending 'zip' (5344 KB)...
OKAY [  0.785s]
writing 'zip'...
OKAY [  9.238s]
finished. total time: 10.023s
processing file 6/6...
sending 'zip' (37547 KB)...
OKAY [  2.358s]
writing 'zip'...
(bootloader) total_image_number=2
Processing [dzdata], please wait...
OKAY [  8.835s]
finished. total time: 11.193s
rompack updated
HBoot pre-update sequence
Restarting phone...
rebooting...
Execution time is 20(ms)
Phone DISconnected
All Done, HTC M8_UL Successfull Repaired 100%
If My Post has Helped you, please PRESS Only THANKS BUTTON
allumts
The Following 5 Users Say Thank You to allumts For This Useful Post:
Old 01-30-2017, 13:56   #2 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 133
thanks dear your file not flashing
OKAY [ 4.673s]
writing 'zip'...
FAILED (remote: 41 model id check fail)
finished. total time: 5.006s
Flash not successfull, reboot will not be done
full in fo
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.15.21331831.A05G
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: XC SHIP S-OFF
(bootloader) serialno: YL}
(bootloader) imei: 352090065656450
(bootloader) imei2: Not Support
(bootloader) meid: 99000499309570
(bootloader) product: m8_whl
(bootloader) platform: hTCBmsm8974
(bootloader) modelid:
(bootloader) cidnum: 11111111
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: off
(bootloader) build-mode: SHIP
(bootloader) boot-mode: RUU
(bootloader) commitno-bootloader: 8a0f02ff
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
Execution time is 17(ms)
Reading secure flag information
... (bootloader) secure_flag: 0
OKAY
Execution time is 15(ms)
Reading CID information
... (bootloader) cid: 11111111
OKAY
Execution time is 12(ms)
Reading MEID information
... (bootloader) meid: 99000499309570
OKAY
Execution time is 14(ms)
Read information completed.
many time try but same problem
Old 01-30-2017, 14:53   #3 (permalink)
allumts's Avatar
Member: 1564612
Lol, Read carefully what model is the Phone.
MY is M8_UL NOT M8_WHL
For lucky i've write that for work with HTC need a small of Basic Knowledge, and seem you have need first os say NOT WORK....
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 01-31-2017, 07:28   #4 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 133
allumts
thanks for replay but boot lodear relocked s-off flash any file upload failed
Old 01-31-2017, 12:38   #5 (permalink)
allumts's Avatar
Member: 1564612
Hello, this isn't Thrad for you Model of phone, not continue more posting Here, becouse this thread is ONLY for HTC M8_UL understand?
Open you own thread about you total different HTC M8_WHL
allumts
Old 01-31-2017, 15:09   #6 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 133
thanks for replay ineed HTC M8_WHL repair file
Old 02-01-2017, 07:51   #7 (permalink)
Member: 2487890
Thanks Meter: 71
Old 02-02-2017, 06:14   #8 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 133
thanks for replay but flashing failed
Traceback (most recent call last):
File "E:\largezip\htc_fastboot\htc_flashzip.py", line 143, in main
File "E:\largezip\htc_fastboot\fastboot.py", line 111, in get_device_serial
File "E:\largezip\htc_fastboot\fastboot.py", line 148, in execute
File "E:\largezip\htc_fastboot\fastboot.py", line 99, in execute
File "E:\largezip\htc_fastboot\fastboot.py", line 83, in _execute_internal
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x8d in position 0: invalid start byte
During handling of the above exception, another exception occurred:
File "htc_fastboot.py", line 187, in main
File "E:\largezip\htc_fastboot\htc_flashzip.py", line 172, in main
AttributeError: 'UnicodeDecodeError' object has no attribute 'message'
File "htc_fastboot.py", line 215, in <module>
File "htc_fastboot.py", line 196, in main
AttributeError: 'AttributeError'
Restarting phone...
rebooting...
Phone DISconnected
Old 02-02-2017, 06:47   #9 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 133
load_file: could not allocate 1645383403 bytes
Old 02-02-2017, 08:09   #10 (permalink)
Member: 190184
Thanks Meter: 31
Phone DISconnected
< waiting for device >
target reported max download size of 1830711296 bytes
Phone connected [SH48EWM00125] *** Fastboot mode
OKAY [ 2.679s]
writing 'zip'...
FAILED (remote: 42 custom id check fail)
finished. total time: 3.029s
This is what i get
Page generated in 0.34914 seconds with 7 queries
