help htc desire 10 compact repair imei hi help repair imei htc desire 10 compact mt6737t read mode fastboot xtc 2clip Reading information... Using Fastboot mode... Reading common information (bootloader) max-download-size: 0x8000000 (bootloader) partition-size:flashinfo: 1000000 (bootloader) partition-type:flashinfo: raw data (bootloader) partition-size:userdata: 32000000 (bootloader) partition-type:userdata: ext4 (bootloader) partition-size:cache: 19000000 (bootloader) partition-type:cache: ext4 (bootloader) partition-size:system: 100000000 (bootloader) partition-type:system: ext4 (bootloader) partition-size:metadata: 2500000 (bootloader) partition-type:metadata: raw data (bootloader) partition-size:nvdata: 2000000 (bootloader) partition-type:nvdata: ext4 (bootloader) partition-size:frp: 100000 (bootloader) partition-type:frp: raw data (bootloader) partition-size:persist: 3000000 (bootloader) partition-type:persist: ext4 (bootloader) partition-size:tee2: 500000 (bootloader) partition-type:tee2: raw data (bootloader) partition-size:tee1: 500000 (bootloader) partition-type:tee1: raw data (bootloader) partition-size:keystore: 800000 (bootloader) partition-type:keystore: raw data (bootloader) partition-size:secro: 600000 (bootloader) partition-type:secro: raw data (bootloader) partition-size:oemkeystore: 200000 (bootloader) partition-type:oemkeystore: raw data (bootloader) partition-size:seccfg: 80000 (bootloader) partition-type:seccfg: raw data (bootloader) partition-size:expdb: a00000 (bootloader) partition-type:expdb: raw data (bootloader) partition-size:cota: 4000000 (bootloader) partition-type:cota: raw data (bootloader) partition-size:apppreload: 14000000 (bootloader) partition-type:apppreload: raw data (bootloader) partition-size:logo: 800000 (bootloader) partition-type:logo: raw data (bootloader) partition-size:recovery: 1000000 (bootloader) partition-type:recovery: raw data (bootloader) partition-size:boot: 1000000 (bootloader) partition-type:boot: raw data (bootloader) partition-size:para: 80000 (bootloader) partition-type:para: raw data (bootloader) partition-size:lk: 80000 (bootloader) partition-type:lk: raw data (bootloader) partition-size:protect2: a00000 (bootloader) partition-type:protect2: ext4 (bootloader) partition-size:protect1: a00000 (bootloader) partition-type:protect1: ext4 (bootloader) partition-size:nvram: 500000 (bootloader) partition-type:nvram: raw data (bootloader) partition-size:proinfo: 300000 (bootloader) partition-type:proinfo: raw data (bootloader) partition-size:preloader: 40000 (bootloader) partition-type:preloader: raw data (bootloader) off-mode-charge: 1 (bootloader) warranty: yes (bootloader) unlocked: no (bootloader) secure: yes (bootloader) kernel: lk (bootloader) product: HQ6737T_66_2IA_M0 (bootloader) version-preloader: 0.1.00 (bootloader) version: 0.5 |
Found anything? I have the same device |
if baseband unknown than try flashing phone |
I am not able to unlock it. Tried every way. |
Sir i doubt unlocking bootloader will do anything Can u check phone settings if baseband version is correct or unknown ?? |
if phone in boot loop than flash first to make phone power up normal |
How do I unlock my Bootloader? it is not taking get_token command OEM unlocking is enabled in developer options. |
Just do fastboot oem unlock and you should be fine. |
Try run command from xtc2clip software @ terminal tab manual command |
