06-08-2018, 15:07 | #1 (permalink) |
Insane Poster Join Date: Oct 2010 Location: colombia
Member: 1431187 Status: Offline Sonork: n/d Thanks Meter: 9 | help htc desire 10 compact repair imei read mode fastboot xtc 2clip Reading information... Using Fastboot mode... Reading common information (bootloader) max-download-size: 0x8000000 (bootloader) partition-size:flashinfo: 1000000 (bootloader) partition-type:flashinfo: raw data (bootloader) partition-size:userdata: 32000000 (bootloader) partition-type:userdata: ext4 (bootloader) partition-size:cache: 19000000 (bootloader) partition-type:cache: ext4 (bootloader) partition-size:system: 100000000 (bootloader) partition-type:system: ext4 (bootloader) partition-size:metadata: 2500000 (bootloader) partition-type:metadata: raw data (bootloader) partition-size:nvdata: 2000000 (bootloader) partition-type:nvdata: ext4 (bootloader) partition-size:frp: 100000 (bootloader) partition-type:frp: raw data (bootloader) partition-sizeersist: 3000000 (bootloader) partition-typeersist: ext4 (bootloader) partition-size:tee2: 500000 (bootloader) partition-type:tee2: raw data (bootloader) partition-size:tee1: 500000 (bootloader) partition-type:tee1: raw data (bootloader) partition-size:keystore: 800000 (bootloader) partition-type:keystore: raw data (bootloader) partition-size:secro: 600000 (bootloader) partition-type:secro: raw data (bootloader) partition-sizeemkeystore: 200000 (bootloader) partition-typeemkeystore: raw data (bootloader) partition-size:seccfg: 80000 (bootloader) partition-type:seccfg: raw data (bootloader) partition-size:expdb: a00000 (bootloader) partition-type:expdb: raw data (bootloader) partition-size:cota: 4000000 (bootloader) partition-type:cota: raw data (bootloader) partition-size:apppreload: 14000000 (bootloader) partition-type:apppreload: raw data (bootloader) partition-size:logo: 800000 (bootloader) partition-type:logo: raw data (bootloader) partition-size:recovery: 1000000 (bootloader) partition-type:recovery: raw data (bootloader) partition-size:boot: 1000000 (bootloader) partition-type:boot: raw data (bootloader) partition-sizeara: 80000 (bootloader) partition-typeara: raw data (bootloader) partition-size:lk: 80000 (bootloader) partition-type:lk: raw data (bootloader) partition-sizerotect2: a00000 (bootloader) partition-typerotect2: ext4 (bootloader) partition-sizerotect1: a00000 (bootloader) partition-typerotect1: ext4 (bootloader) partition-size:nvram: 500000 (bootloader) partition-type:nvram: raw data (bootloader) partition-sizeroinfo: 300000 (bootloader) partition-typeroinfo: raw data (bootloader) partition-sizereloader: 40000 (bootloader) partition-typereloader: raw data (bootloader) off-mode-charge: 1 (bootloader) warranty: yes (bootloader) unlocked: no (bootloader) secure: yes (bootloader) kernel: lk (bootloader) product: HQ6737T_66_2IA_M0 (bootloader) version-preloader: 0.1.00 (bootloader) version: 0.5 |
11-16-2018, 05:19 | #2 (permalink) | |
Junior Member Join Date: Aug 2018
Member: 2854913 Status: Offline Thanks Meter: 0 | Quote:
Found anything? I have the same device | |
11-18-2018, 03:03 | #4 (permalink) | |
I am not able to unlock it. Tried every way. | |
12-09-2019, 06:41 | #8 (permalink) | |
How do I unlock my Bootloader? it is not taking get_token command OEM unlocking is enabled in developer options. | |
12-15-2019, 17:33 | #9 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Just do fastboot oem unlock and you should be fine. | |
12-17-2019, 03:12 | #10 (permalink) |
Member: 2854913 Status: Offline Thanks Meter: 0 | I tired. The command runs for forever, doesn't give an unlock screen or anything else. When I hit the command it just goes on like nothing has happened and stay connected in fast boot mode |
