07-29-2019, 14:05 | #1 (permalink) |
Crazy Poster Join Date: Aug 2017
Member: 2743735 Status: Offline Thanks Meter: 0 | HTC U11 Life Unlock From what I can tell I need to use the PowerAdapter Tools Tab. I was able to 1. unlock the bootloader and 2. copy the files to the XTC 2 clip. I plugged the power adapter into the XTC2Clip, and the USB cable from the power adapter into the computer. Then I put the SD card into the phone, and connected the phone to the computer. However this is what I get when I try to unlock: "Starting PowerAdapter procedure: Detected model: HTC U11 Life (Android 8.x) Special recovery file is available 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... XTC 2 Power adapter not found. Please connect it to USB port Request completed" How do I fix this, or does this mean my Power Adapter does not work??? |
07-29-2019, 22:53 | #4 (permalink) |
Member: 2743735 Status: Offline Thanks Meter: 0 | I found the drivers on this site, installed, restarted and tried again, but the same results. Starting PowerAdapter procedure: Detected model: HTC U11 Life (Android 8.x) Special recovery file is available Flashing special recovery ... please wait a moment Special recovery was flashed successfully 1. Checking phone connectivity....... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... XTC 2 Power adapter not found. Please connect it to USB port Request completed |
08-29-2022, 20:09 | #5 (permalink) |
Insane Poster Join Date: May 2018
Member: 2840553 Status: Offline Thanks Meter: 2 | hello, I have the same situation, earlier on this computer I unlocked without problems, now it does not work. help solve the problem... 2022-08-29_192013.png 2022-08-29_192035.png |
