Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 02-07-2017, 15:23   #1 (permalink)
Member: 2146046
Thanks Meter: 62
Question [HELP] HTC One M9 AT&T Unlock Issue
Hello,
I am randomly having issues with XTC Clip not unlocking HTC One M9's for AT&T. I have tried to re-image the XTC Clip multiple times and it does not seem to fix the issue. Steps I am doing are listed below.
1. Write Data to XTC Clip for HTC One M9 / M9 Sprint Unlock Option
2. Insert XTC Clip into HTC One M9 SD Card Slot (SD Card is detected in storage settings)
3. Enable USB Debugging on HTC One M9
4. Plug USB into HTC One M9 --> Phone is detected by XTC Program
5. Boot phone into FTM Mode through XTC Software Button to try and unlock the phone
6. Phone seems to boot into FTM mode, but unlock process does not work.
7. Phone reboots, I see HTC Splash screen, Phone hangs on black screen for about three seconds (Should be longer when working) but the phone never unlocks. Even after doing this multiple times.
What could be causeing the phone not to unlock? Am I doing something wrong?
I have had many success with unlocking this phone. But this issue seems to happen a lot. Usually when this process works, I either see a black screen with XTC clip software text on screen....or the phone hangs on a black screen for like 15 secons. My problem is I dont see any of this, After rebooting to FTM the phone just seems to reboot without unlocking or doing anything.
Please help support. This is happening to multiple phones.
Thanks!!!!
Old 02-09-2017, 10:02   #2 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 248
Originally Posted by gtrader View Post
hello,
i am randomly having issues with xtc clip not unlocking htc one m9's for at&t. I have tried to re-image the xtc clip multiple times and it does not seem to fix the issue. Steps i am doing are listed below.
1. Write data to xtc clip for htc one m9 / m9 sprint unlock option
2. Insert xtc clip into htc one m9 sd card slot (sd card is detected in storage settings)
3. Enable usb debugging on htc one m9
4. Plug usb into htc one m9 --> phone is detected by xtc program
5. Boot phone into ftm mode through xtc software button to try and unlock the phone
6. Phone seems to boot into ftm mode, but unlock process does not work.
7. Phone reboots, i see htc splash screen, phone hangs on black screen for about three seconds (should be longer when working) but the phone never unlocks. Even after doing this multiple times.
What could be causeing the phone not to unlock? Am i doing something wrong?
I have had many success with unlocking this phone. But this issue seems to happen a lot. Usually when this process works, i either see a black screen with xtc clip software text on screen....or the phone hangs on a black screen for like 15 secons. My problem is i dont see any of this, after rebooting to ftm the phone just seems to reboot without unlocking or doing anything.
Thanks!!!!
used sd mode editor.................
The Following User Says Thank You to skyulock For This Useful Post:
Old 02-09-2017, 14:37   #3 (permalink)
Member: 2146046
Thanks Meter: 62
Does SD Mode Editor work for HTC One M9 Unlock?? Are you positive?
Old 02-13-2017, 14:34   #4 (permalink)
Member: 2146046
Thanks Meter: 62
Can I get some support with this issue? Any help or reasons as to why this happens would be nice
Old 02-13-2017, 17:10   #5 (permalink)
Member: 2416253
Thanks Meter: 4,097
Hello,
Sorry for late answer.
I have forwarded this to our developers, but we can't find any reason for this problem yet. I will keep you posted.
P.S. Did you try to replace flex?
Old 02-13-2017, 23:23   #6 (permalink)
Member: 2146046
Thanks Meter: 62
Originally Posted by xtc2clip View Post
Hello,
Awesome! Thanks! Yes I have tried to replace flex. I can try another one but Im not sure that is the issue because SD flex is detected by phone and program. The problem is the Unlock process isnt starting up after booting to FTM Mode. The phone just reboots. This happened on four different phones. Some will work, others will just not unlock and will reboot to system without unlocking.
Old 02-14-2017, 11:10   #7 (permalink)
Member: 2416253
Thanks Meter: 4,097
Just to clarify - do they all have same firmware/bootloader, etc versions?
Old 02-15-2017, 14:38   #8 (permalink)
Member: 2146046
Thanks Meter: 62
I'm not 100% sure I had to unlock them via code because I couldn't get them unlocked with XTC Clip and I do not have those phones with me anymore sadly. If I come across issue again, I will try and write down Firmware / Bootloader version.
Old 03-15-2017, 18:00   #9 (permalink)
Member: 2146046
Thanks Meter: 62
Ok so I am experiencing the same issue....there is seriously something wrong with the way XTCCLIP unlocks AT&T HTC ONE M9's. I have two phone here everything is being done 100% right. Card is not broken, SD card is not broken, flex isnt broken.
One PHone is on Android Version 6.0 HTC Sense 7.0 Software # 3.38.502.41.
The Other Phone is on Android Version 5.1 HTC Sense 7.0 Software # 2.11.502.18
Both of these phones when booted to FTM Mode just boot right back up. I do not see XTC Diag Screen to unlock or phone does not sit on black screen which usually means its getting unlocked. After inserting XTC SD Card and Selecting Boot to FTM Mode Button in software phone reboots to FTM then just instantly boots back up without getting unlocked.
What is up with this issue? Really frustrating because I have a lot of these phones I need to unlock and am doing everything right.
Old 03-15-2017, 19:31   #10 (permalink)
Member: 2146046
Thanks Meter: 62
Tried to test it some more.....
Now the ONLY TWO PHONES out of like 7 phones that seemed to unlock were these two after a bunch of attempts.
Android Version 5.1
HTC Sense 7.0
Software Number 2.11.502.18
and
Android Version 5.1
HTC Sense 7.0
Software Version 2.6.502.16
Most of the phones that didnt work were on android 6.0 / 6.1 - Please help need some support for this issue as I unlock M9 AT&T phones daily...
Old 03-21-2017, 17:44   #11 (permalink)
Member: 2146046
Thanks Meter: 62
any help would be much appreciated
Page generated in 0.34381 seconds with 7 queries
