08-14-2015, 08:19 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: australia
Member: 721542 Status: Offline Thanks Meter: 56 | Help with unlock or soff Desire 510 anything wrong with the steps or box got damaged? after those steps nothing changed. then i try the direct mode. clearsimlock, after a while window pop up then I click on yes, nothing happening same situation here with writing CID on it. |
08-14-2015, 09:40 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Let me guess, your card is not registered or not upgraded? Please install drivers from support area first, you can't even read information from phone with your current drivers! |
08-14-2015, 13:07 | #3 (permalink) |
Freak Poster Join Date: Sep 2014
Member: 2260725 Status: Offline Sonork: 100.1668393 Thanks Meter: 20 | Install The Drivers Below link..Even i got the same Issue ,,XTC Team Solve my problem Thnk u XTC2cLIP http://xtc2.net/downloads/HTCDriver.msi |
The Following User Says Thank You to sameerkhan651 For This Useful Post: |
08-15-2015, 05:20 | #4 (permalink) | |
Member: 721542 Status: Offline Thanks Meter: 56 | Quote:
what can i do with it now? | |
08-15-2015, 10:11 | #7 (permalink) |
Member: 2260725 Status: Offline Sonork: 100.1668393 Thanks Meter: 20 | Solution Block the Antivirus/Turn off/ Or Disabled, And Click Next.& Register If u Still stuck with same Problem= pls change ur SD Reader...Dats it.. 100% work |
