10-10-2017, 04:06 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | How to remove FRP U ultra? [SOLVED] pls hlep me all user and supporter. |
10-10-2017, 07:26 | #2 (permalink) | |
No Life Poster Join Date: May 2014 Location: Nigeria
Member: 2192386 Status: Offline Thanks Meter: 50 | Quote:
Always search forum before posting,it might have been posted before. Sent from my HTC One mini 2 using Tapatalk | |
10-10-2017, 08:01 | #3 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
all i do ready and with power adapter but still not remove ,that's y i ask for help. | |
10-10-2017, 11:36 | #5 (permalink) | |
Starting FRP unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Waiting for the server to process request, it may take up to 5 minutes... Your request was processed successfully! Unlock token has been obtained Removing FRP ... Done. FRP was removed. Phone DISconnected but phone still not remove. | |
10-10-2017, 11:52 | #6 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | here with power adapter Starting FRP unlock procedure Phone detected, reading token... Token detected successfully Removing FRP ... Done. FRP was removed. Phone DISconnected |
10-10-2017, 12:10 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | factory reset than try again if still same than flash phone and try again |
The Following User Says Thank You to deepakgarg For This Useful Post: |
02-26-2018, 13:59 | #9 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Gemany Age: 41
Member: 9493 Status: Offline Thanks Meter: 9 | ... Hello, got the same Problem with an U Ultra. Tried more then once to remove FRP but its still locked. Flashed the Phone aswell and tried again but FRP is still on. Any hint what I can do to remove the FRP Lock? |
05-08-2018, 17:04 | #10 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2350594 Status: Offline Thanks Meter: 9 | Starting FRP unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Waiting for the server to process request, it may take up to 5 minutes... Your request was processed successfully! Unlock token has been obtained Removing FRP ... Done. FRP was removed. |
06-08-2018, 23:29 | #13 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1255872 Status: Offline Thanks Meter: 5 | Hi, I try to remove FRP from U ultra but only say this: Starting FRP unlock procedure Phone detected, reading token... Error: Unexpected token format (1): ... (bootloader) INFO< Please cut following message > (bootloader) INFO<<<< Identifier Token Start >>>> (bootloader) INFO16A4613CBD631DCFB5D189FF3B6D991A (bootloader) INFOC15231EC31C4385D23D0796891F0E367 (bootloader) INFOF7B5A41A60BA8056DE653EF00B58E337 (bootloader) INFO3C20A35771EE6E3B8D739ED5D05F6298 (bootloader) INFO382732E38DB0256B72B1BC9FA83CD3C9 (bootloader) INFO0278115C10BA6E100046030E1AEC286E (bootloader) INFOBD97DD5F4741F92924FB5ADF17DE9753 (bootloader) INFOB0C39C269E5001608D18D3ECFBB8D10C (bootloader) INFO692F339E774200B3FE54841DADF45CF1 (bootloader) INFOA23C10453DA67E9C54803AF582D0ACD9 (bootloader) INFO094ACE571B4A46D60AD7F34B07BFD7B6 (bootloader) INFOD0B3B23BD5FB4ED9E9069767D2C4605B (bootloader) INFOA8F1128933CEE12AA202F0F18317188A (bootloader) INFOF7BEF01FFFADD038F92A0FF482D7BF7F (bootloader) INFO3886CD090BB742E23CA13A35B90C90B0 (bootloader) INFOA3CC60016E1A2A6FCBB7FE0CA4E3C7B5 (bootloader) INFO<<<<< Identifier Token End >>>>> OKAY Execution time is 1(s) Please, I need your help to remove FRP. Thank you |
07-25-2018, 20:41 | #15 (permalink) |
Freak Poster Join Date: Dec 2009 Location: egypt
Member: 1188874 Status: Offline Sonork: 100.1610116 Thanks Meter: 8 | Same here Starting FRP unlock procedure Phone detected, reading token... Token detected successfully Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Waiting for the server to process request, it may take up to 5 minutes... Your request was processed successfully! Unlock token has been obtained Removing FRP ... Done. FRP was removed. NOT DONE even format then unlock again |
