Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 10-10-2017, 04:06   #1 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
How to remove FRP U ultra? [SOLVED]
I have HTC U Ultra locked FRP ,so how to remove it with xtc2clip?
pls hlep me all user and supporter.
Old 10-10-2017, 07:26   #2 (permalink)
Member: 2192386
Thanks Meter: 51
Go to FRP tab and click "Remove FRP (New method). That should work and you must be connected to the internet.
Always search forum before posting,it might have been posted before.
Sent from my HTC One mini 2 using Tapatalk
Old 10-10-2017, 08:01   #3 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
if u don't know i search or not ,u must be don't write that.
all i do ready and with power adapter but still not remove ,that's y i ask for help.
Old 10-10-2017, 11:29   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
Please use FRP (new method) option, if it doesn't work correctly - post log and we will help
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 10-10-2017, 11:36   #5 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Originally Posted by xtc2clip View Post
Hello,
Starting FRP unlock procedure
Phone detected, reading token...
Token detected successfully
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Waiting for the server to process request, it may take up to 5 minutes...
Your request was processed successfully! Unlock token has been obtained
Removing FRP ...
Done. FRP was removed.
Phone DISconnected
but phone still not remove.
Old 10-10-2017, 11:52   #6 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
here with power adapter
Removing FRP ...
Phone DISconnected
Old 10-10-2017, 12:10   #7 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
factory reset than try again
if still same than flash phone and try again
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 10-11-2017, 15:19   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
You don't need to use PowerAdapter to remove FRP. Just use XTC 2 Tool.
Old 02-26-2018, 13:59   #9 (permalink)
Member: 9493
Thanks Meter: 9
Hello,
got the same Problem with an U Ultra.
Tried more then once to remove FRP but its still locked.
Flashed the Phone aswell and tried again but FRP is still on.
Any hint what I can do to remove the FRP Lock?
Old 05-08-2018, 17:04   #10 (permalink)
Member: 2350594
Thanks Meter: 9
Removing FRP ...
Old 05-08-2018, 17:04   #11 (permalink)
Member: 2350594
Thanks Meter: 9
No lo elimina, por favor ayuda, gracias.
Old 05-08-2018, 20:37   #12 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Factory reset and try again
Sent from my iPhone using Tapatalk
Old 06-08-2018, 23:29   #13 (permalink)
Member: 1255872
Thanks Meter: 5
Hi, I try to remove FRP from U ultra but only say this:
Error: Unexpected token format (1): ... (bootloader) INFO< Please cut following message >
(bootloader) INFO<<<< Identifier Token Start >>>>
(bootloader) INFO16A4613CBD631DCFB5D189FF3B6D991A
(bootloader) INFOC15231EC31C4385D23D0796891F0E367
(bootloader) INFOF7B5A41A60BA8056DE653EF00B58E337
(bootloader) INFO3C20A35771EE6E3B8D739ED5D05F6298
(bootloader) INFO382732E38DB0256B72B1BC9FA83CD3C9
(bootloader) INFO0278115C10BA6E100046030E1AEC286E
(bootloader) INFOBD97DD5F4741F92924FB5ADF17DE9753
(bootloader) INFOB0C39C269E5001608D18D3ECFBB8D10C
(bootloader) INFO692F339E774200B3FE54841DADF45CF1
(bootloader) INFOA23C10453DA67E9C54803AF582D0ACD9
(bootloader) INFO094ACE571B4A46D60AD7F34B07BFD7B6
(bootloader) INFOD0B3B23BD5FB4ED9E9069767D2C4605B
(bootloader) INFOA8F1128933CEE12AA202F0F18317188A
(bootloader) INFOF7BEF01FFFADD038F92A0FF482D7BF7F
(bootloader) INFO3886CD090BB742E23CA13A35B90C90B0
(bootloader) INFOA3CC60016E1A2A6FCBB7FE0CA4E3C7B5
(bootloader) INFO<<<<< Identifier Token End >>>>>
OKAY
Execution time is 1(s)
Please, I need your help to remove FRP.
Thank you
Old 06-15-2018, 17:21   #14 (permalink)
Member: 2416253
Thanks Meter: 4,162
Thank you
Hello!
Thank you, just found your message unreplied, did you solve your problem?
Old 07-25-2018, 20:41   #15 (permalink)
Member: 1188874
Sonork: 100.1610116
Thanks Meter: 8
Same here
Removing FRP ...
NOT DONE
even format then unlock again
Page generated in 0.20357 seconds with 8 queries
