Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 05-16-2018, 10:50   #1 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 160
How to s-off m8 (Help)
hello friends, i actually want to install custom rom on m8, but i cant flash custom recovery, becos it say i cant flash it on s-on state, but have manage to unlock boot loader
Question:
1.How can i s-off my htc m8?
2.just incase i cant s-off, i can flash official firmware, to do dat i will need to Relock bootloader, How can i relock My boot loader ?
Old 05-16-2018, 12:40   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,072
to s-off u can use sdmode method or direct method in xtc2clip software
to relock bootloader send command "fastboot oem lock"
Old 05-16-2018, 13:05   #3 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 160
Not working
E:\ANDRIOD OS\Compressed\Compressed\fastboot_adb(1.0.32)_0711 14_r21>fastboot devices
FA597YJ02384 fastboot
E:\ANDRIOD OS\Compressed\Compressed\fastboot_adb(1.0.32)_0711 14_r21>fastboot oem lock
FAILED (remote: unknown command)
finished. total time: 0.010s
Old 05-16-2018, 13:07   #4 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 160
Any other way to lock d bootloader?
Old 05-16-2018, 13:24   #5 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,072
do u have xtc2clip ?
Old 05-16-2018, 13:42   #6 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 160
yes
i do have Xt2clip
Old 05-16-2018, 13:47   #7 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 160
wat do i do with d xt2clip to lock the bootloader
Old 05-16-2018, 13:47   #8 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,072
go to terminal tab and type oem lock
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 05-16-2018, 17:55   #9 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 160
Thanks it worked
*** Command started ***
... (bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp
(bootloader) [KillSwitch] Last Byte is 0X01, enable unlock
(bootloader) RELOCK device
OKAY
Execution time is 93(ms)
*** Command finished ***
The Following User Says Thank You to successnbd For This Useful Post:
Old 05-18-2018, 13:36   #10 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 160
Currently have not been able to still fix my device
My challenge is i cant flash flash custom recovery
i told maybe if i flash custom os, it would solve it
but when i am flashing twrp, i get errors
Old 05-18-2018, 14:08   #11 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,072
problem with emmc as it seems
Old 05-19-2018, 20:36   #12 (permalink)
Member: 2416253
Thanks Meter: 3,756
Well you shouldn't have locked the bootloader then.
What's the problem with S-OFF? You can try both direct method and SD-card mode method.
Page generated in 0.29539 seconds with 7 queries
