10-17-2016, 11:31 | #3 (permalink) |
No Life Poster Join Date: Dec 2010 Location: pakistan
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | Sending oem writecid 11111111 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) a51dtul_init_sd, SD card already power on (bootloader) a51dtul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 1677724173 (bootloader) erase_grpmult: -1921008716 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 OKAY Execution time is 2(s) Operation finished Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) a51dtul_init_sd, SD card already power on (bootloader) a51dtul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: -1921008652 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] verify javacard: get signature fail, SW= 6f00 (bootloader) writesecureflag: Permission denied, value 4 OKAY Execution time is 2(s) Operation finished |
10-17-2016, 12:07 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | u need to connect xtc clip2 to phones sdcard slot first than put phone in fastboot mode |
The Following User Says Thank You to deepakgarg For This Useful Post: |
10-18-2016, 14:39 | #7 (permalink) |
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 01.01.010_U10305041_08.01.51015 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.11.401.6 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: SH54JYC02328 (bootloader) imei: 355721062320694 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: a51_ul (bootloader) platform: hTCBmsm8939 (bootloader) modelid: 0PFJ40000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: da038a09 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 0001 all: Done! Execution time is 15(ms) Reading secure flag information ... (bootloader) secure_flag: 0 OKAY Execution time is 15(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 15(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 0(ms) Read information completed. |
10-18-2016, 15:43 | #9 (permalink) |
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | Starting flash process... target rom version: 3.17.401.3 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (49306 KB)... OKAY [ 3.034s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... FAILED (status read failed (Too many links)) finished. total time: 7.287s Flash process completed. Flash not successfull, reboot will not be done |
10-18-2016, 15:51 | #10 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
