02-08-2016, 13:42 | #7 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, I believe I have already answered you in Skype, but your error means correct files are not copied, or it's a filesystem failure, in this case you need to repair: http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ and then repeat again. |
12-18-2016, 14:17 | #12 (permalink) |
Insane Poster Join Date: Apr 2015 Location: S Y R I A
Member: 2383669 Status: Offline Thanks Meter: 10 | Hello Connect xtc and select special unlock then choose 626s and select unlock boot loader then copy files after that enter device to FTM Mode you can press only ftm mode after xtc2clip connected to your device or you can go to FTM manual Hold Volume UP then power for 5 sec after that to know if this work go to download mode volume down then power and check if boot unlocked then he sucses with unlock another method download 5.1.1 RUU and then s-off and downgrade should work i test unlock to device to 5.1.1 and 6.0.1 And Work |
12-22-2016, 07:59 | #13 (permalink) |
Major Poster Join Date: Aug 2014 Location: surat Age: 34
Member: 2235420 Status: Offline Thanks Meter: 9 | thanx 4 help team....htc 6262s metro pcs unlock done after s-off and downgrade 5.1.1....work like charm |
The Following User Says Thank You to starele_surat For This Useful Post: |
